jp525 Posted February 8, 2007 Report Share Posted February 8, 2007 I did a clean install on a new drive of ultimate. the plan was to take the old drive ,leave xp on it but make it the secondary. Vista works fine, in the bios I can see both drives properly identified as primary and secondary. I can see them in the device manager, but the secondary drive will not mount, it does not show up in my computer. If I switch the pins and cable and put it back as master it boots and runs fine. am I missing something, is this a vista surprise. what next, i have tried jumper settings. the new drive is a WD(250) and the secondary is a Maxtor(40) I dont want to format the 40 and lose the files. any ideas? thanks for your input. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted February 8, 2007 Report Share Posted February 8, 2007 Have you had a look in disk management, you may have to initialise it.Click on the Start Button and right click on Computer and select Manage. Expand the Storage section and select Disk Management. Quote Link to comment Share on other sites More sharing options...
jp525 Posted February 11, 2007 Author Report Share Posted February 11, 2007 Have you had a look in disk management, you may have to initialise it.Click on the Start Button and right click on Computer and select Manage. Expand the Storage section and select Disk Management.thanks, It still will not mount. I installed a 256 video card and vista runs like it should, but still no access to the old 40 gig. it shows up in device manager any other ideas? Quote Link to comment Share on other sites More sharing options...
