indigestion Posted February 24, 2007 Report Share Posted February 24, 2007 I'm trying to open a file with the extension *.dzip. When opening the file in a texteditor such as notepad, I find this://..[DDZip]ZipEngine=DDZip 1.1;ZipCreation=06.10.2006 11:01:41;ZipApplication=;ZipContext=RAP_SINGLE_ZIP_V2;ZipElement=001 of 001;RecordCRC=-1363155428;...//It seems like the zipengine used is called DDZip 1.1. Have anyone ever heard about something like that?I've tryed to open the file in winzip whitout any solution. (errormessage: "not valid archive")Any suggestions? Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted February 24, 2007 Report Share Posted February 24, 2007 http://downloads.vnunet.com/download/compr...zip/_12540.html Quote Link to comment Share on other sites More sharing options...
cozofdeath Posted February 24, 2007 Report Share Posted February 24, 2007 Compressed files, these days anyhow, never have ascii text as a header or anything because everything is compressed. You may have a very old version of a dziped file or it may be something else. If you think there is a chance you think it could be malicious in any way when you uncompress it run an dzip -l filename to see what all files will be extracted. I say to do this because the v2.9 and probably previous versions of dzip have a coding error which can allow attackers to decompress files to any directory, like a startup directory. So if any files are not present when extracted is not good. Quote Link to comment Share on other sites More sharing options...
