Winlogon.exe Help
hammb
My computer unfortunately got a virus (Trojan) in the winlogon.exe file
My anti virus software was not able to clean the virus or delete the file so I stopped the process and deleted the file (winlogon.exe). Then I copied the good winlogon.exe file from a backup source and pasted in the c:\windows\system32 folder.
Now I get stuck in the endless Reboot Loop
I tried going to the recovery console and reconfiguring the boot.ini file (sounded good at the time)
and this did not help.
I replaced the winlogon file again via the recovery console and still... the reboot loop.
Can anyone point me in the right direction ?
Thanks
B
I can get to the safe mode menu screen... I've tried Safe Mode, Safe Mode with Networking, Safe Mode with command prompt, Last Known Good Configuration, you name it.. i tried it.
The problem is... right when the login screen is supposed to pop up.. where you select the account to log into... the PC reboots. Every time. Everything seems to run smoothly up to that point as if nothing was wrong.
I can get to the recovery console without a problem... Any other ideas?
Thanks
You can run a chkdsk /r from the recovery console.
Another good idea might be to restore the original winlogon.exe.
Boot the recovery console
log into your installation
CD system32
REN winlogon.exe winlogon.old
CD dllcache
Then, replace it with the one on the CD.
expand D:\i386\winlogon.ex_ -r c:\windows\system32
The above assumes your hard drive is C, and the CD-ROM is D.
I've tried both suggestions without success
Chkdsk took an hour and a half last night and did manage to make at least 1 repair.
Ive renamed and copied the winlogon.exe file from 2 different XP CDs and I still get stuck in the reboot loop. I am trying to avoid hooking this HD up as a slave, copying the important data and doing a fresh install.
Any other ideas?
Thanks for all you help.
