autostart for usb
firmadankt
Hi,
I noticed that there are usbsticks with an autostart function. I mean, you plug in your stick and the software on the stick starts.
Does someone know how this works?
I noticed that there are often two partitions on the device, on fat-partition and one that is formatted like a cd (cdfs) with an autorun.inf. The second partition is able to autostart, becausw windows seems to recognize this as a cd.
But how to bring a "cd", an iso or a cdfs-partition on a usbstick??
thx for answers
It requires the autorun.inf file, with a few parameters as to what you want it to do. You need to open a notepad document, add the lines of code you want and save it as autorun.inf. Just click save as > all types and call it autorun.inf and put it on the root of your flash drive.
Basically this is what it would contain:
[autorun]
open=setup.exe
icon=icon2.ico
