Mcafee removal problems
I was running Mcafee enterprise version provided by my company. When I realized it was no longer updating I purchased the latest version from Mcafee and started to install it. It stopped and said I had to remove enterprise version first. I went to add/remove programs and tried to remove it but it crashed. It no longer showed in add/remove programs but was still on the machine. So I deleted all references to network associates from the registry and it seemed to get rid of it.
Now when I open the Mcafee install file all I get is a blank window. I decided to do a system restore but that just opens up a blank window too. I get blank windows or non functioning windows when running several other applications as well. For the most part my computer runs fine. I have tried safe mode but no luck. Unfortunately I have a gateway with OEM version of windows, so I can't even re-install windows.
Any ideas what I have done?
Are you sure that you don't have Windows on a hidden partition on the machine?
I no expert on Gateway machines but I thought that there was a recovery partition that could be used to restore the computer back to its factory condition.
Yes I can do a restore, but it would overwrite all of my applications. I would prefer not to have to reinstall everything again.
Hi,
Try 21 days trial version Your Uninstaller 2006!.
I'm using this software now and It work fine, I like it.
It's not just an ordinary uninstaller program, this one remove unused left-over registry and file. One sophiscated feature, called 'Advance uninstall' may help you remover your undiscover program;-mcafee.
BE very careful with the 'Disk cleaner', it will complicated your system once you click that so it's not wise to use that feature. For final clean-up just use Ccleaner will do.
I would suggest you remove Your uninstaller, and run system restore if u manage to sovle your problem but it still your call to restore back to last good settings.
Good luck.
Let us know the outcome so at least some other member can post u other alternative.
