administrator rights...installation help
Hey everyone. I have bought a Windows Vista Home premium, after installation I wantet to install a ADSL software but when I run the installation file it says to me something like that : You dont have administrator rights on this account, please log in with the adminstrator rights and make installation again.
There a one thing I dont get with it, you see when I install thise software I do install it with administrator rights...can u please tell me what I should do?
Maybe I need to reinstall Vista?
Thank you for your time!
Taken of another forum.
When you run a setup program, UAC should automatically prompt you to run it as an administrator using the UAC prompt (which Microsoft calls the “consent” prompt). If you don’t see this, right-click the program, and then click Run As Administrator. Then, it will really run as an administrator. It should have prompted you, but for some reason, Vista didn’t realize it needed Administrator rights. It woudln’t hurt to check the software developer’s website for a version of the program made for Vista; that would also fix the problem
