roeyz Posted May 3, 2007 Report Share Posted May 3, 2007 hi all...well having a lot of problems with loading my windows...it will get so far then it will try again,,,sometimes my computer will just turn it self off complietly,,,takes like 10 attempts to load in,,,then when im on it a while..everything will just freeze up..i try the ctrl/alt/del...nothing...so i have to turn it of @ the mains...i dunno if its my fan..cause really ..it is sounding a little noisy....i hope sum1 cld give me a idea what this problem could be..and maybe tell me how to resolve this matter...ty for taking the time to read my post..thanks all Quote Link to comment Share on other sites More sharing options...
-pops- Posted May 3, 2007 Report Share Posted May 3, 2007 I think you've answered the problem in your title.Power supply units do seem to deteriorate with age/use and become less able to provide the extra bit of "oomph" (technical term) to get a computer going. I've known this happen on a number of machines - especially recently when previously it was a rarity.I would look at replacing the power supply unit. Assuming it's a normal desktop machine, the unit will be fairly standard ATX PSU which can be obtained in a number of maximum power outputs. If you're familiar with the inside of your computer, have a look at the unit that's installed already and get a replacement unit of about 50 (or more) Watts output over and above the present one. Quote Link to comment Share on other sites More sharing options...
roeyz Posted May 3, 2007 Author Report Share Posted May 3, 2007 I think you've answered the problem in your title.Power supply units do seem to deteriorate with age/use and become less able to provide the extra bit of "oomph" (technical term) to get a computer going. I've known this happen on a number of machines - especially recently when previously it was a rarity.I would look at replacing the power supply unit. Assuming it's a normal desktop machine, the unit will be fairly standard ATX PSU which can be obtained in a number of maximum power outputs. If you're familiar with the inside of your computer, have a look at the unit that's installed already and get a replacement unit of about 50 (or more) Watts output over and above the present one.thanx 4 the reply appreciated...cld there be a fault in my power supply cable? Quote Link to comment Share on other sites More sharing options...
-pops- Posted May 3, 2007 Report Share Posted May 3, 2007 I'm fairly sure that a cable fault would show itself by at least part of the machine not working at all. Quote Link to comment Share on other sites More sharing options...
