Guest moon Posted July 21, 2003 Report Share Posted July 21, 2003 I want to build a dedicated sound machine from scratch. I'm thinking P4 at the moment as I'm told that it's hard to quieten down AMD's. Any comment on that. for starters ? Quote Link to comment Share on other sites More sharing options...
Tankus Posted July 21, 2003 Report Share Posted July 21, 2003 AMD's run hot, compared to p4's so they need the cooling....makes sense..Saying that my older 8OO Athlon which is networked into my main 2000 stores all my music on a 20 and 80 Gb hard drives, through a Digital Dolby 5.1 Cambridge sound-works 5 point, plus a sub woofer, it does it for me.....!Do you really need a P4....? , get a cheaper older chip and motherboard , and spend it on the soundcard and the speakers......My Hifi sits dead and unloved in the corner of my dinning room, I think its been years since Ive stuck a CD in it...... Its not just the sound , Its the ease of stacking up the tunes....... Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted July 21, 2003 Report Share Posted July 21, 2003 or get one of the p4 celerons,you can get a 2.0ghz for £60 with a heatsink/fan included. Quote Link to comment Share on other sites More sharing options...
Guest moon Posted July 21, 2003 Report Share Posted July 21, 2003 At times I'll be using up to four simultaneous audio inputs so I'm going to need a card with a break-out box and a cpu that can cope. I currently use a Soundblaster Live Platinum but it's limited and there are latency issues with my existing Pentium 3 600. Quote Link to comment Share on other sites More sharing options...
