Thatsmyname Posted June 9, 2007 Report Share Posted June 9, 2007 Hi,I hope that someone has an idea of what I need to do to get a laptop working. XP Home, SP2, IE7, latest updates, AVG AV.When I try to start up IE7, Control Panel or Explorer, it doesn´t start. I have seen that the processes iexplorer.exe is running in the application menu, but the frame is not occuring on the screen. I´ve scanned the HD with AVG and Adaware, but no viruses were found. I have also tried to boot with the latest working configuration, but no.I have run out of ideas. Does anyone have any suggestion of what I can do. Or do I need to reinstall the whole XP pack again?BregsTN Quote Link to comment Share on other sites More sharing options...
-pops- Posted June 10, 2007 Report Share Posted June 10, 2007 I take it as read that you don not have a backup of your system. When you get back working again, I strongly recommend that you make a full system backup and keep it up to date.Back to your immediate problem, can you do a System Restore to a time before this failure occurred?Failing that, you could attempt to repair your installation see click here or here. Quote Link to comment Share on other sites More sharing options...
