speeding up/ removing junk from XP
Ralph
i have a car pc and am running xp pro. mainly i was wondering has anyone managed to get any very fast boot times on here? or if anyone has tryed?
mine boots up in about 40secs, or comes back from hibernate in 25secs.
taking in to consideration its a low power 12v setup with a jetways 1500mhz board/chip, with 512 rams, on board graphics.
40gb 2.5inch IDE drive, to which i may upgrade to a sata.
how can i make it faster??
Ralph
If you go to Run and type in msconfig, that will open up a new window. Click on the "Startup" tab and that lists all the programs that start when your computer boots. You can go through them and uncheck ones you don't want starting.
WARNING: They are often oddly named; if you don't know what it is, don't touch it.
Welcome to the Windows Forum.
Removing general junk from a PC - check out CCleaner.
Removing junk from startup - Startup Inspector.
Defragmenting your HD or partitions from time to time also helps to keep performance.
More important than the three points above, make sure that your system is free of any malware.
Seshomaru Samma's link contains a recommendation to use a registry cleaner. My recommended CCleaner also contains a registry cleaner.
I would just like you to be careful; registry cleaners may remove lots of harmless stuff from the registry, but there is always a chance that something may get irreparably damaged.
Therefore, before you start using any registry cleaner, please backup your registry! ERUNT is a very good tool that does just that, and it takes very short time to make a full registry backup; for details and download see http://www.larshederer.homepage.t-online.de/erunt/.
  • 2 weeks later...
but then again , if you want this "car computer" to be faster , it kind of makes me wonder why you are running XP..?
mainly because im using odd hard ware, and AHK as a software langage and using 98 would make things very difficult. tho 98 is way way faster.
i know nothing of linux of macs, but i see using a different opperating system causing issues when i plug in unrecognised memory sticks etc, 98 often asks for its setup disk.
Ralph
