K-MAC Posted July 15, 2007 Report Share Posted July 15, 2007 Hello, every 3 to 5 times a start my PC (before windows loads up) I get the message "System Battery Voltage is Low" I'm assuming it's something to do with the bios, but being a bit of a newb at these things I don't really know what to do.Do I need to replace my bios or can it be re-charged in some way.Thanks. Quote Link to comment Share on other sites More sharing options...
andsome Posted July 15, 2007 Report Share Posted July 15, 2007 If it's the Bios battery, they are cheap and easy to replace. They are of the watch battery type. :D Quote Link to comment Share on other sites More sharing options...
K-MAC Posted July 15, 2007 Author Report Share Posted July 15, 2007 I just found a giude on how to replace it, thanks. Quote Link to comment Share on other sites More sharing options...
andsome Posted July 16, 2007 Report Share Posted July 16, 2007 I just found a giude on how to replace it, thanks.Turn off the computer first at the wall, and either buy a wrist strap or hold the metal case with the other hand to earth everything. :D Quote Link to comment Share on other sites More sharing options...
