3 problems
MS Paint
well i had rocketdock, and put MS Paint in there, then when i clicked it i went down and it was lagging so it pulled MS Paint out of the rocket dock and deleted it. Anyway i can get it bak? For the mean while i got this crappy MS Paint that only saves in BMP
Images
Images look "funky" when i open them i got to choose which pogram to open it with
the name of the images, and everything else in the destop are sorrunded with gray :S
pic:
can someone plz help me to get the "good" ms paint bak, automatically open images: "bmp, png, jpg,..." with windows picture and fax viewer.
also to change the icon of images "bmp,png,jpg,..." to the regular kind.
and remove the icon names to be sorrounded by gray, to transparent and font to black.
thank u
