ps/2 ps2 cable convert
I don't think it can be done easily.
If you have a spare PCI slot on your machine, probably the simplest procedure would be to install another set of USB ports. PCI USB cards are easily obtainable, simple to fit and not expensive.
pops idea will be your best bet though I do have one myself. I would let you have it with pleasure except I would not be able to sell the keyboard/mouse without it. It came with a keyboard and mouse that independently have PS2 connectors on them which plug into the small box similar to your picture then a single USB lead goes to the PC. The idea is so that they can be used either through PS2 ports or a single USB one.
Sorry man no spare PCI slots its a xbox.
theres a converter they have that converts a controller port into a keyboard and mouse output "picture1"
and i have a wireless keyboard and mouse that connects through a single usb male. i was wanting the name of the cable that would plug into the purple and green output and then convert into a usb female
