problem installing
hi, i bought a new laptop acer and it is not is installed with any OS, so i have a dvd on windows vista. when, 'ON' the laptap it shows
grub> how do i access my dvd files from grub commands for windows vista installation.?
Pls help as i do not know any of this commands.
or how do i set it to dos to acess my dvd with windows vista.
i have already set boot up with cd rom.
pls help . tq
Grub is a boot loader typically used for Linux.
If you do not use Linux, you can remove this and install Windows Vista on its own. I am not sure if grub supports the format command, so you may want to boot from the Windows Vista DVD and format the drive before the installation. Most computers can boot from cd/dvd, you may need to check in your bios settings to set the cd/dvd as the 1st boot device.
