NikoTheRuso Posted September 10, 2007 Report Share Posted September 10, 2007 I always get this error and it’s impossible to author my DVD with Architect 4.0:WARNING: An error occurred while writing a file. Invalid data was encountered when processing an MPEG file.These are the steps I take: after editing my movie in Final Cut Pro I then export the movie into QuickTime format, the resulting .mov I compress using a compressor to mpg2 (mpeg-2?) format. The resulting audio file (.aiff) I convert to wave (.wav), then this audio file plus the m2v I import into architect 4.0 along with a .PSD file for the DVD menu, no subtitles... I do all that is needed to produce the master DVD... the preview looks fine and there is no problem but when I prepare to burn the DVD in the middle of the process the error appears.I have tried several times with different videos but it is always the same thing and I cannot burn my video. I will appreciate help solving this problem. Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 10, 2007 Report Share Posted September 10, 2007 Your processing scheme seems extraordinarily complex. Do you have a special reason for using this method?I'm not familiar with Architect software but what I do when making a DVD from AVI, WMV, MPG etc., I load the file(s) into my video editor - usually WinDVD Creator and process from there. I don't separate video and audio, just process as one unit after editing.Have I missed the point? Quote Link to comment Share on other sites More sharing options...
