nareloc Posted September 24, 2007 Report Share Posted September 24, 2007 How can I stop programmes automatically loading when I re-boot? I have gone to msconfig and de-activated the programmes I don't use, which is great as long as I put the pc on standby, but if I shut down and restart they are all there agin in the system tray - slowing down the startup every time. I am running Windows XP HomeMany thanks Quote Link to comment Share on other sites More sharing options...
andsome Posted September 24, 2007 Report Share Posted September 24, 2007 START UP INSPECTOR from hereMuch better to leave ms config alone. Quote Link to comment Share on other sites More sharing options...
andsome Posted September 24, 2007 Report Share Posted September 24, 2007 nareloc, I'd just like to confirm andsome's suggestion of using startup inspector. Many people, both experienced and otherwise get lulled into editing things themselves and find it very tricky to disable auto-launching programs. In some cases the programs themselves will have an option in 'Settings' or 'Options' which will allow one to change it easily. It is often not so easy. Without getting too detailed, programs can be automatically launched from the config.sys, autoexec.bat, winstart.bat, win.ini, wininit.ini and services.msc files, not to mention the dozen or so registry keys which store launching information, and the more simple 'Startup' folder. Attempting to change these things manually often leads to your computer exploding...BANG! :D :D Quote Link to comment Share on other sites More sharing options...
nareloc Posted September 24, 2007 Author Report Share Posted September 24, 2007 Thanks for the advice. I have run Startup I and will keep an eye on things to see how it goes.nspector Quote Link to comment Share on other sites More sharing options...
andsome Posted September 24, 2007 Report Share Posted September 24, 2007 Thanks for the advice. I have run Startup I and will keep an eye on things to see how it goes.nspectorDon't forget to click on CONSULT. :D Quote Link to comment Share on other sites More sharing options...
