renaming system accounts?
xion344
Hi there.
I just typed in: - rename the guest and administrator accounts - into the Google search bar, pressed go, and it came back with quite a lot.
Here are some. You didn't say what Operating System or server. Click on links below.
http://support.microsoft.com/kb/816109
http://support.microsoft.com/kb/320053
http://roawtech.wordpress.com/2007/10/22/g...min-account-xp/
http://www.google.com/search?q=rename%20th...ator%20accounts
Hope this is of some help.
Click the start menu and select the icon next to your name at the top. A user accounts window pops up. From here press the back button twice. You now have a "Change an account" setting, click that and select the account you want to rename and click "change my name" to change it. If your guest account is on you should be able to change the name from here (mines off).
Hope this helps you. ;)
