Techin Posted November 9, 2007 Report Share Posted November 9, 2007 I have windows XP Pro and I recently installed and uninstalled some trial software and somehow it must have deleted some necessary file for my CD/DVD Drives. My CD-Rom, DVD Drives and my virtual CD Drives all now show "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)" I have tried to uninstall and reinstall and reinstall drivers but no change. I would suspect a hardware issue but I have Windows 2000 on a different Hard Drive for safety and troubleshooting purposes and the CD/DVD drives are fine there. If I am missing a file I can replace it from another computer or CAB file but I will need to know which files to look for and check. If the software made a change to the registry on where to find the file I would like to know the relevant registry entries so I can check their paths. Normally I would have tried a restore but in a cleanup of the drive the restore points were lost. Not to swift I realize... but to late now. :( Can someone point me to the relevant files and registry entries? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 9, 2007 Report Share Posted November 9, 2007 It is very difficult to make driver changes directly in the registry. I have tried that myself some time ago, and failed.If you look at your Device Manager, does the CD/DVD driver look OK, or does it have a yellow exclamation mark? Quote Link to comment Share on other sites More sharing options...
Techin Posted November 9, 2007 Author Report Share Posted November 9, 2007 It is very difficult to make driver changes directly in the registry. I have tried that myself some time ago, and failed.If you look at your Device Manager, does the CD/DVD driver look OK, or does it have a yellow exclamation mark?All with yellow exclamation mark and even the standard cd-rom driver errors out as corrupt when I try to reinstall Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 9, 2007 Report Share Posted November 9, 2007 What does "errors out" mean - can you give us the exact error message and/or code you are getting?Does the standard CD-ROM driver also has a yellow mark?Can you try to download the driver(s) from the specific manufacturer? Quote Link to comment Share on other sites More sharing options...
Techin Posted November 9, 2007 Author Report Share Posted November 9, 2007 What does "errors out" mean - can you give us the exact error message and/or code you are getting?Does the standard CD-ROM driver also has a yellow mark?Can you try to download the driver(s) from the specific manufacturer?When I manually try to install the Generic CD-ROM driver it errors out with the same error "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)" that shows on each CD-ROM entry in the device manager and will not install. I checked the details for the drivers and there is a GEARaspiWDM.sys driver that is not Microsoft’s. I checked the entries for this driver in the registry and the path had been redirected by putting a ? mark where the : should have been. It read C?\WINDOWS\system32\Drivers\GEARAspiWDM.sys but even when I changed it to read C:\WINDOWS\system32\Drivers\GEARAspiWDM.sys it still didn't correct the problem. I searched and found a GEARaspi.dll entry with the same incorrect path statement. I corrected it as well with still no results. I hope if I can just get this driver removed from my cd-rom drivers it will fix the issue. But I don't know how to do this. Safely Quote Link to comment Share on other sites More sharing options...
Techin Posted November 9, 2007 Author Report Share Posted November 9, 2007 Well I finally found the crux of the problem although I am sure there is still some leftover crap in the registry but I found an entry in the system event viewer that referenced a failed load on a file called pxHELP20 and found that it was listed as the high filter while the other file mentioned before was listed as the low filter. I traced it out in the registry and found it had a missing related sys file so I deleted the entries related to pxHELP20 on the high filter (whatever that is) and my CD-ROMs are back... whew... risky move but it worked out. I hate trialware lol Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted November 9, 2007 Report Share Posted November 9, 2007 I've had this happen before as well. Might want to save this for future reference.http://support.microsoft.com/kb/314060 Quote Link to comment Share on other sites More sharing options...
Techin Posted November 9, 2007 Author Report Share Posted November 9, 2007 I've had this happen before as well. Might want to save this for future reference.http://support.microsoft.com/kb/314060Thanks Scarecrow I read the article and it is just the thing that was needed... Quote Link to comment Share on other sites More sharing options...
