Guest spikeychris Posted August 4, 2003 Report Share Posted August 4, 2003 NTL digital. Quote Link to comment Share on other sites More sharing options...
Guest LB Posted August 4, 2003 Report Share Posted August 4, 2003 ahh..never used ntl digital...will have a look for instructions. Quote Link to comment Share on other sites More sharing options...
Guest spikeychris Posted August 4, 2003 Report Share Posted August 4, 2003 God bless ya! Quote Link to comment Share on other sites More sharing options...
Guest LB Posted August 4, 2003 Report Share Posted August 4, 2003 What the BBC actually do (and ITV as well, check out Trisha or Emmerdale) is take the 4:3 content and zoom up to 14:9 within a 16:9 frame.Hence the end result is it looks perfect on analogue which always shows 16x9 content in 14x9 and gives a black bar on the left and right on digital. Whichever way you look at it, it will never be a perfect solution but any attempt to broadcast in widescreen should be applauded. Quote Link to comment Share on other sites More sharing options...
Guest LB Posted August 4, 2003 Report Share Posted August 4, 2003 and the instructions for NTL RGB switching:-Press TV guide on your remoteSelect option 4 Options Select option 4 TV Screen Settings Select Video output to TV & change from Composite to RGB & then press TVyour scart lead should be connected to scart socket 1 on your TV as this is the one which has RGB capability (if you connect this through a video it will not work) Quote Link to comment Share on other sites More sharing options...
Guest spikeychris Posted August 4, 2003 Report Share Posted August 4, 2003 MASSIVE thanks to Lived Backwards followed the instructions to the T and all is perfetcamundo.......like avin a new tele...I STRONGLY advise all to do the same...Chris Quote Link to comment Share on other sites More sharing options...
bvw Posted August 4, 2003 Report Share Posted August 4, 2003 Coronation Streets on.........I nearly got throttled, can't go anywhere near the TV until it's finished :D Quote Link to comment Share on other sites More sharing options...
Guest spikeychris Posted August 4, 2003 Report Share Posted August 4, 2003 Bryan, hope you managed to get it done between Coronation St and Eastenders, I got baaaaad looks whilst Roy Cropper was coughing up and she could only see it in a one" screen Quote Link to comment Share on other sites More sharing options...
bvw Posted August 4, 2003 Report Share Posted August 4, 2003 :) Emmerdale Farm/Constipation Street/Eastenders!She's happy, thats all that matters :) Spooks soon I think, hooray! :D Quote Link to comment Share on other sites More sharing options...
Guest LB Posted August 4, 2003 Report Share Posted August 4, 2003 Coronation Streets on.........I nearly got throttled, can't go anywhere near the TV until it's finished :DBVW, you need to have a second remote that she doesn't know about and use it to keep turning the tele over, do it a couple of times and watch the steam rise!!! :lol: :lol: :lol: Quote Link to comment Share on other sites More sharing options...
Guest spikeychris Posted August 4, 2003 Report Share Posted August 4, 2003 So pleased I started this thread, I've done a bit of ferreting around at appears that RGB is a purer signal and therefore better quality (drives theelectron guns of the TV directly) WOW I've got GUNS in my tele....... I'd of paid more if I knew... Quote Link to comment Share on other sites More sharing options...
bvw Posted August 4, 2003 Report Share Posted August 4, 2003 Lived Backwards.........you must think I'm mad, I don't have a death wish you know ;) ......messing about with the TV whilst the soaps are on, she'd kill me! After all these years I know my place :D Sorted the Tv by the way, slightly different with Telewest, set it to RGB....sorted!Must go now, my little nest of vipers is calling............... Quote Link to comment Share on other sites More sharing options...
Guest LB Posted August 4, 2003 Report Share Posted August 4, 2003 for monkey... Quote Link to comment Share on other sites More sharing options...
