blueeyes Posted November 22, 2007 Report Share Posted November 22, 2007 Respected Helpers,My PC was nonbrandedPro.......... 2.4GhzM/B......... D845GBVunfortunately my m/b was burnt out, never display again. I purchased a mother board from Compaq Evo 510 PC in used condition.I have a problem, After succesful POST my PC didn't load windows untill I press F1 key and the error is "512-Chasis fan not detected". Any help will be appriciated.I am using ATX casing of my old pc with every setting.Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted November 22, 2007 Report Share Posted November 22, 2007 Either one of your fans is playing up or you have a loose connection.How many fans do you have in your computer?. Quote Link to comment Share on other sites More sharing options...
blueeyes Posted November 23, 2007 Author Report Share Posted November 23, 2007 I have a fan in the power supply and the other one on Processor. Only two of them.Either one of your fans is playing up or you have a loose connection.How many fans do you have in your computer?. Quote Link to comment Share on other sites More sharing options...
wickedadmin Posted December 7, 2007 Report Share Posted December 7, 2007 I think in most BIOS you can disable that feature. And since it sounds like there's no system fan, then why not. Quote Link to comment Share on other sites More sharing options...
