xion344 Posted November 26, 2007 Report Share Posted November 26, 2007 i think one of my hardwares are defective because my pc just shuts down randomly on its own >_> Quote Link to comment Share on other sites More sharing options...
-pops- Posted November 26, 2007 Report Share Posted November 26, 2007 Can you check the situation in the Event Viewer?RIGHT click My Computer -> Manage -> Event Viewer. Quote Link to comment Share on other sites More sharing options...
ithonicfury Posted November 26, 2007 Report Share Posted November 26, 2007 Does it actually shut down (like if you went to Start > Shutdown), or does it just power off? (or does it reboot?)If it reboots then chances are that it could be a driver problem or memory issue maybe (just the main two of many issues it could be). You could run memtest86 (you should be able to find it by googling, and on their site will be instructions on how to use it) on it to see if its memory. Also Right Click on My Computer, go to Properties, Advanced, Startup and Recovery (i think thats what its called), and where it says something like On System Failure:, uncheck Reboot automatically.Then the next time it happens you'll get a blue screen with some error codes which you can then post or google to see whats wrong. Quote Link to comment Share on other sites More sharing options...
