rado Posted December 6, 2007 Report Share Posted December 6, 2007 Hi all,I've got a problem with UNICODE. When I start application receive message "The output char buffer is too small to contain the decoded characters, encoding 'Unicode (UTF-8)' fallback 'System.Text.DecoderReplacementFallback'. ..." What can I do ???" Thank you in advance Rado Quote Link to comment Share on other sites More sharing options...
Irene Posted December 6, 2007 Report Share Posted December 6, 2007 Someone seems to have had a similar problem/error in the following...LOOK HERE Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted December 7, 2007 Report Share Posted December 7, 2007 Welcome to the Windows Forum.This is obviously a problem with the application you are using; they should use wchar (wide characters) for Unicode handling. I found a similar problem with a Symantec application; see http://support.veritas.com/docs/292818I think the best is to contact whoever developed the application you are trying to use. Quote Link to comment Share on other sites More sharing options...
