Beginner Help - Laptop to wireless network connectivity issue
luke1206
Hi
Most grateful if anyone could help me do a bit of diagnosis. I have a new work laptop (Dell Latitude D630, XP) that picks up wireless networks ok at work (when it is set to "at home site" on the Novel login screen), but won't seem to pick-up the wireless network at my parent's house (when set to "Not at Home Site"). I have another Dell loptop which picks up my parent's network fine, so the issue is not with that.
The D630 can access the web perfectly through an Ethernet cable connected to Virging Media cable service at my flat. I had issues connecting to this at first but they were solved by running the VM set-up CD.
Would anyone know if there is a way to solve this?
Many thanks,
Luke
