Clipboard Issues
kakabel
I have not been able to figure out why despite intense searching, but recently every image that I paste from the clipboard has a black background? I checked my alternate computer and not so - everything there works fine, white on white, animations work, so it has to be a setting issue somehow, but I just can't figure it out? Help please.
Welcome to the Windows Forum.
Please be more specific: paste into what? Which operating system? What's the difference between the two systems?
Also, if the trouble started recently, have you tried a System Restore to a time before it started?
I'm sorry - Windows XP. Both of my desk top computers carry the same system. I cannot do a system restore to any time before it started on the one that is the problem, and I don't know that I could pin that point in time down exactly. About three months ago my computer "crashed" - would not open Windows period, and I had an IT analyst come to my home as I was in a panic due to the fact that while I had everything saved, I was in the middle of Photoshop project for my job that had a deadline attached to it, and which if I lost would have been more than a major disaster. I tried system restore but it did not work. He was able to save my files even though I had to reinstall all of my programmes, but there is now no way for me to get to a point before that time.
Re what am I pasting into? - It could be a Power Point slide, or just simple email. Frequently I will go onto a Free clipart site if I am in a hurry and find an image or a small animation where in the past I have been able to right click. copy and paste into anything that I wanted, email, an empty slide, just about anything and have it transport exactly as on the site, now I can still do it on computer No. 2, but not on the problem computer. Since I use my computer primarily for graphic design project and projects involved with my art, I am probably going to switch to a Mac sooner or later, but for now I need the clipboard to work.
Thank you for responding.
Try hosting the image with a black background on a free hosting site such as http://imageshack.us and load the image up on another computer. Does the black background still appear?
It is possible it has something to do with your computers display.
Surely if I host the image though I will have to save it in order to upload it, and if I save the image there is no problem. White or transparent backgrounds remind as is, and animations work. It is the copying and pasting that seems to have gone awry. I checked the display and all seems to be in order.
I am going to attempt copying the clipboard files from the system 32 folder on the "good" computer to the one that is giving me problems and see what happens. I refuse to give up though, as every problem has a solution - somewhere - I hope.
Sigh...
To be honest, I have never tried to paste an image into anything - Photoshop, Powerpoint, E-mail, etc. I always 'Insert' images from a saved location.
What happens if you use this "normal" method? (I am not suggesting this as a permanent solution; just see how this works.)
