need help finding audio drivers please help me.
Most audio drivers are already known to Windows XP; did you try to find it using 'Add Hardware'?
If Windows XP cannot find it, you will have to look for it by specifying the exact audio controller you have in your laptop. Do you have it listed somewhere in your specs? If not, check if SIW can find and list it.
