Mouse pointer not staying the same when I reboot
Have you tried re-setting them again? There must be something there that you're missing on the way, like "set as default settings" or something like that.
Also, are you using the built-in Windows mouse utility from Control Panel>Hardware? Perhaps it's being over-ridden by your mouse software; or vice versa. Also check your mouse software help file for advice. :flowers:
