How to install XP on to a new hard drive - HELP!
I am upgrading my girlfriend's compact Fujitsu P2110 which is 7 years old. I've maxed out on RAM already, also bought a new battery. Now I am about to install a new hard drive. I've looked at her supplied disks. She bought the P2110 in Hong Kong. There is a Fujitsu recovery disk but no Windows XP disk. It looks like XP was preinstalled. There is the original Windows sticker on the laptop.
How would I get the OS moved over on to a new hard drive?
Will that be on the Recovery disk?
I really just want to do a clean reinstall of XP. There is precious little data on the laptop that I want.
Have you actually looked at the recovery disk? Most likely, everything will be on the recovery disk.
The Recovery disk hads 4 options. None of them look like clean install. I'm at work and can't recall what they were.
Apparently the HD has a 1.5 GB partition with an image of the HD. This is loist if I reintall. I need to clone in order to save this. Why would I want to save that?
Will I also have to download tons of drivers if I do a clean reinstall?
If there is no Windows recovery disk, or a Windows recovery partition, then I would do something like
  • install Acronis True Image
  • make a backup image (maybe on the new disk, partitioned, and mounted as an external disk?)
  • replace the disk
  • restore the backup image onto the C: partition of the replaced disk
  • reboot Windows
