jboard1 Posted June 5, 2008 Report Share Posted June 5, 2008 So here is the situation - I have setup an old box I had laying around as an XP machine that is being used for a file server/back up machine on my home network. I am running vista and remotley accessing the XP server. While I am remoted in, i can't move any windows that are open, nor can i resize them. It was an original base XP pro image with no updates on it. So as I type, I am installing all the updates necessary. I can't imagine it would be an update issue though. Does anyone have any ideas of why this may be happening?p.s. - when i access the machine locally i can resize and move windows normally...Thanks,Jeff Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted June 6, 2008 Report Share Posted June 6, 2008 There's a number of stuff it could be.What i'd expect is RAM. lol. But i've got a personal hatred for RAM issues from my past machines so i'm probably wrong is making that assumption.Doesn't Vista have a problem closing/minimizing/resizing windows anyway? I'm sure i've seen posts about it on forums before. Quote Link to comment Share on other sites More sharing options...
jboard1 Posted June 6, 2008 Author Report Share Posted June 6, 2008 I have it all updated now, and remoting in from Vista, I still can't move/resize any windows. However, there is another XP machine in the house, so I used that to remote in to the XP "file server". While remoted in from that machine, I could move/resize windows. So it is definitly an issue from Vista to XP. But i can't find anyone else that has experience this problem, so I am not sure if it is a universal issue or maybe that the remote desktop clients are different versions and are not compatible. Anyone have any ideas? Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted June 6, 2008 Report Share Posted June 6, 2008 http://thevistaforums.com/http://winvistaforums.com/Try asking on them forums. :DI think it's something to do with Vista to XP though.. :P Quote Link to comment Share on other sites More sharing options...
jboard1 Posted June 6, 2008 Author Report Share Posted June 6, 2008 awesome, thanks for the info! hope that helps B) Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted June 6, 2008 Report Share Posted June 6, 2008 Ahah! You are most welcome. :D Quote Link to comment Share on other sites More sharing options...
