Flash Player - HELP!!!
Razarex
I cant watch some videos on youtube and other sites because I dont have the latest flash player. I used to use Opera browser but I am now using Firefox. I have downloaded the installer for Flash player version 9.0.124.0 and installed it. It didn't have any effect at all however. I installed it again and when I looked at the 'show details' tab on the installer it says it is installing it to the Opera plugin folder. I dont know how to change it so that it installs it to my Firefox plugin folder. I even tried moving the files that it installs into the opera plugins folder to the firefox plugins folder. It didnt work.
PLEASE CAN SOMEONE HELP ME!!!!!
First download new opera 9.5 Download
Second download and install flash player
You must close Opera when you install flash player.Thats all
Firefox and Opera have same Flash player plugin
Opera is much better for me.
Before proceeding with the above instructions, I recommend to download and run the Flash Player Uninstaller from http://kb.adobe.com/selfservice/viewConten...rnalId=tn_14157; this will make sure that any old or corrupted Flash Player parts are removed. Make sure that all browsers are closed when you run the uninstaller.
