Internet Problems
Ashley
I have a laptop running Windows Vista. It has both Firefox and IE7 on.
I keep randomly getting their respective 'server not found' messages when browsing, on both browsers. Webpages work after they are refreshed once, twice and sometimes more times.
It seems to happen more often with secure sites that you have to log in to.
I run windows firewall, so i doubt that is the problem, and after scanning i dont seem to have any malware etc
It is a very irritating problem so i would appreciate your help
Thanks in Advance
How is the laptop connected to the Internet?
If wirelessly, are you sure your wireless system/connection is reliable? I've given up using wireless systems because of problems like you are experiencing
