Brgsousa Posted July 28, 2008 Report Share Posted July 28, 2008 Hi,I have two PCs which can ping each other. Windows XP, configured in the same network (ie: 192.168.2.0/255.255.255.0). There is NO firewall enabled.BUT i am trying to use remote control software and I can't do it. Both Real VNC and Remote control from Windows are not working.Situation A:PC 1 as client and PC 2 as server ==> WORKSSituation B:PC 2 as client and PC 1 as server ==> NOT WORKINGBoth have the server application enabled and working.Any Ideas?Regards Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted July 29, 2008 Report Share Posted July 29, 2008 I prefer TightVNC, and make sure you install client and server on both, and configure both. You could always reinstall them to be sure. Quote Link to comment Share on other sites More sharing options...
Brgsousa Posted July 29, 2008 Author Report Share Posted July 29, 2008 I thought it could be something related to Windows Master Browser. But I tryed ip address too, and it did'nt work. Quote Link to comment Share on other sites More sharing options...
mtrx Posted July 29, 2008 Report Share Posted July 29, 2008 Did you try :Log in to PC2start>run>cmd>telnet PC1.Ipaddress 5900If there is no responce so you do not have RealVNC service running or VNC server runing on that port is disabled by Firewall(by default the port is tcp 5900)Log in to PC1 start>run>cmd>netstat -anb | find /i "5900"There should be a record somethink like thisC:\>netstat -anb | find /i "5900" TCP 0.0.0.0:5900 0.0.0.0:0 LISTENING 2196If you do not have the record lyou might be sure that the VNC server is not runing.If you have that record you might have problem with your firewallTry to disable it with this commandstart>run>cmd>netsh firewall set opmode disable (Windows firewall only)If you wish paste Logs from commands from PC1telnet 127.0.0.1 5900andnetstat -anbI recomend to use UltraVNC if you wish to use programs like RealVNC .UltraVNC is more secured Quote Link to comment Share on other sites More sharing options...
AnandN Posted July 30, 2008 Report Share Posted July 30, 2008 Hi If you want to access your both Machine through Remote Control than Forgot VNC its a Very Complicated tool.down load Damware from [b]http://www.damware.com. you will just need to download Both (Server & Client ) than install on your Machine (server.exe on pc2 & Client.exe on Pc1 ) than you can Access PC 1 through pc 2but but Client Cant Access your PC2(Server)its very simpale Application to use. Quote Link to comment Share on other sites More sharing options...
