Whoseondephone Posted July 29, 2008 Report Share Posted July 29, 2008 I recently had some strange things happen to my windows machine. First let me tell you about my colorful setup:I'm running a PIII 1Ghz, 512MB RAM 133MhzAGP: 4x Geforce FX 5200PCI: Sound Blaster live 16bit, Linksys LNE 100 Ethernet Adapter, IEEE 1394 SBP2 Device, USB 2.0 card,2 IDE hard drives.2 optical drives.My original power supply stopped working so I found one from a PII system that was berried in my friends room. My original power supply had a power rating of 250W and fit correctly inside of the computer case. My current power supply has a power rating of 200W and kind of hangs in the open case in this empty spot below the hard disks.OK OS time: I had 3 partitions running 3 different flavors of windows. First I installed windows xp sp2. Second Windows 2003 server sp2. Third Tinny 2003 eXPeriance edition. (a striped down version of windows)Here is my problem. I hot plugged my firewire hard drive into the 1394 card and the whole computer froze, mouse and all. I had to reboot. When I rebooted Windows froze at the windows boot screen (the moving bar thing froze). So I decided that maybe I blew the firewire/1394 card. After taking It out the computer boots fine. So next I try putting it in a different PCI slot. the computer freezes during boot. So then I take the card to another computer and find out that the card works perfectly in there. I tried booting in different OS's with the card in and the same thing happened in all of them. There were 2 instances where windows froze even with the card out of the computer. So now i pop in a Linux live CD and sometimes it boots and sometimes it doesn't. So now I decide to reformat. Windows installs fine. When i get back I find that windows froze on the first boot. So then I rip out all of my PCI cards. The computer boots fine. I put them back in in a different order. The computer boots fine but can't find my firewire1394 card. After a closer look I notice that my card isn't inserted in all of the way. I insert the card and everything seems to be working now. I'm hoping I could receive some clarity on this issue. My guess is that perhaps the power supply is to weak. I don't really understand the whole case power supply motherboard relationship.I've been running this setup like this for at least 6 months and haven't had any problems like this. I'd love to hear some feed back.One things for sure. I'll never hot plug anything into a computer again. :D Thanks Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted July 29, 2008 Report Share Posted July 29, 2008 My original power supply stopped working so I found one from a PII system that was berried in my friends room. My original power supply had a power rating of 250W and fit correctly inside of the computer case. My current power supply has a power rating of 200W and kind of hangs in the open case in this empty spot below the hard disks.Thats why :DI dont think 200w is enough, especially if you have multiple pci cards. Might want to bump that up. I just put a 500w in a p4 (mind you it uses more power) but It's not going to be enough with a lot of usb/firewire and pci devices attached to it drawing power.Also, your computer started with 250, you added more devices. add more power for those devices ;) Quote Link to comment Share on other sites More sharing options...
