iTunes shortcut not working
I've recently upgraded to version 7.7.1.11 of iTunes and for the first time ever, I can't get my iTunes shortcut to work :huh:
I usually copy the iTunes icon from the desktop to the section in my screenshot directly below (I don't know the actual name of the area highlighted in red)
When I do what I have always done in the past i.e. copy the icon into that particular area, I get this error message when I click on it: :huh:
Any ideas on how to get a working shortcut icon?
Thanks.
How about making your own shortcut? (From Windows Explorer, right-click drag-and-drop the original itunes.exe as a shortcut into that target area.)
It worked but not as you said although your method gave me a clue, thanks :flowers:
In the past I either left-clicked (or right clicked) dragged-and-dropped and it worked, it used to say 'Shortcut to iTunes'
However this method no longer works and I have to select the 'Copy Here' option :huh:
In any case I'm happy as I now have all my favourites in the same place (whatever it's called)
p.s. I've not seen that menu before as I used to use the above method in the past.
