Raccoon1400 Posted October 10, 2008 Report Share Posted October 10, 2008 I just did a repair (upgrade) install to fix a problem in the registry. That problem is now fixed, but now my sound card is not seen by the computer.I have a dell running Vista. The card is Sigma tel. It does not show up in device manager now, the only thing under the sound card section is a high definition audio codec.How can I get the computer to see my sound card so I can install it? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 10, 2008 Report Share Posted October 10, 2008 Try http://www.drivermax.com/ - it can find devices and supplies the latest drivers. (Only 32-bit Windows, no 64-bit.) Quote Link to comment Share on other sites More sharing options...
froggystyle Posted October 10, 2008 Report Share Posted October 10, 2008 I just did a repair (upgrade) install to fix a problem in the registry. That problem is now fixed, but now my sound card is not seen by the computer.I have a dell running Vista. The card is Sigma tel. It does not show up in device manager now, the only thing under the sound card section is a high definition audio codec.How can I get the computer to see my sound card so I can install it?If its a Dell Pc then you could look for the service tag somewhere on the unit, if it has this and has the original sound card in then you can go to the Dell website and search for drivers against your service tag..... Quote Link to comment Share on other sites More sharing options...
Raccoon1400 Posted October 10, 2008 Author Report Share Posted October 10, 2008 I just did a repair (upgrade) install to fix a problem in the registry. That problem is now fixed, but now my sound card is not seen by the computer.I have a dell running Vista. The card is Sigma tel. It does not show up in device manager now, the only thing under the sound card section is a high definition audio codec.How can I get the computer to see my sound card so I can install it?If its a Dell Pc then you could look for the service tag somewhere on the unit, if it has this and has the original sound card in then you can go to the Dell website and search for drivers against your service tag.....I'll try that. I can install drivers even if the device doesn't show up in device manager? Quote Link to comment Share on other sites More sharing options...
Seshomaru Samma Posted October 11, 2008 Report Share Posted October 11, 2008 I can install drivers even if the device doesn't show up in device manager?yes Quote Link to comment Share on other sites More sharing options...
Raccoon1400 Posted October 11, 2008 Author Report Share Posted October 11, 2008 Driver downloaded from dell using service tag. I'll install when I get a chance, hopefully today. Quote Link to comment Share on other sites More sharing options...
Raccoon1400 Posted October 11, 2008 Author Report Share Posted October 11, 2008 Installing the driver made no difference whatsoever.http://support.dell.com/support/downloads/...p;fileid=195627 Quote Link to comment Share on other sites More sharing options...
Raccoon1400 Posted October 12, 2008 Author Report Share Posted October 12, 2008 Solved by uninstalling the sigma tel audio program, then installing the driver.PS. Can I mark this as solved? Quote Link to comment Share on other sites More sharing options...
