Bunty Posted October 13, 2008 Report Share Posted October 13, 2008 i got two lan cards installed in my systemone is Dlink and other one is intel inbuilt.Now i have just installed a graphic card into my system right next two the dlink lan card. Day before yesterday i face problem accessing internet as my lan was give me RTO and when i disable and enable it it give me one reply after that no reply. I thought that lan card is gone so i inserted the lan wire into Intel lan card i was getting proper replies.Now what i did i took out the lan card (dlink) and inserted it into another port a little far from the graphic card.i was getting full replies. What can be the problem again after sometimes i see RTO but the net works just fine. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted October 13, 2008 Report Share Posted October 13, 2008 It could be heat related, as the card worked OK when you moved it farther away from the graphics card. Quote Link to comment Share on other sites More sharing options...
