MartinStatic Posted October 26, 2008 Report Share Posted October 26, 2008 Hey there.After wading through the internet for a fix that works, I thought it better to just ask for help myself.I have Vista running perfect with sound and its Sigmatel Hi-Def whatnot.But after installing 2003 onto a separate partition, and booting that, there is no noise.Vista still has sound fine, but 2003 does not.Assuming it was a simple compatibility error that could be fixed with a patch or drivers, I looked on the net, to no prevail.Please help. No Volume bar or anything, and Windows shows ''Microsoft UAA Bus Driver for High Definition Audio'' in Device Manager as broken; more specificallyDevice Status''Windows cannot initialize the device driver for this hardware. (Code 37)Click Troubleshoot to start the troubleshooter for this device.''Any help would be appreciated.Also, my first post, so um, hello world. Quote Link to comment Share on other sites More sharing options...
-pops- Posted October 26, 2008 Report Share Posted October 26, 2008 Have installed the audio drivers in full on the 2003 installation? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 27, 2008 Report Share Posted October 27, 2008 If you look in the Device Manager, do you see any yellow exclamation marks? Quote Link to comment Share on other sites More sharing options...
MartinStatic Posted October 27, 2008 Author Report Share Posted October 27, 2008 If you look in the Device Manager, do you see any yellow exclamation marks?Yeah, on the ''Microsoft UAA Bus Driver for High Definition Audio'', I'll give more details in the morning, its 4am here now heh.Thanks anyways for noticing me. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 27, 2008 Report Share Posted October 27, 2008 If you open 'Properties' on that tagged item, you should get more info what the problem is (error number). There should also be a troubleshooter that would help you to resolve the problem. Quote Link to comment Share on other sites More sharing options...
MartinStatic Posted October 27, 2008 Author Report Share Posted October 27, 2008 Okay I'm awake now...Any other questions? All drivers I tend to download seem to be incompatible, and other people on the net seem to have the same problem; only one by one they all seem to be fixed with the right downloads; none of which have worked for me.Pfft. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 28, 2008 Report Share Posted October 28, 2008 Uninstall the driver with the yellow mark, then use http://www.drivermax.com/ to get information on exactly what your audio device is. Unfortunately DriverMax does not have drivers for 2003, but with the correct identification you will be able to find the proper driver somewhere.P.S. and yes, I am in Tokyo. Quote Link to comment Share on other sites More sharing options...
