Scifiman Posted November 26, 2008 Report Share Posted November 26, 2008 Im trying to get my microphone to work, and i can send voice clips but when someone sends me a video call they cant hear me. the mic isnt muted. cause i can make voice clips. any advice? Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted November 26, 2008 Report Share Posted November 26, 2008 You need to run through the installation and configuration set up. Should be under Actions or something in a conversation window.You'll then have a test whether you can hear a beep or something then it will need to test your voice, also choose which piece of audio device you are using to get the audio back and also which piece you want to use to speak in to. Quote Link to comment Share on other sites More sharing options...
