Amara Posted January 4, 2009 Report Share Posted January 4, 2009 I have recently noticed that Norton Security Scan keeps installing on my computer seemingly on its own. I remove it with the add/remove programs and it comes back hours later. I also tried to remove it with the Norton Removal Tool and that didn't work either. I have a feeling this got installed with an update I did recently, such as Shockwave. I heard that installs it automatically unless you tell it not to. I am running Windows XP Home. Any suggestions as to how to get rid of this for good would be greatly appreciated. Thanks!! Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 4, 2009 Report Share Posted January 4, 2009 Recently lots of softwares install unwanted programs. Always be careful to uncheck "offers" for free software when installing new - especially free - programs. See http://www.calendarofupdates.com/updates/i...showtopic=16109As for uninstalling Norton Security Scan, removing it from Add/Remove Programs should do the job. If it "comes back", that would classify it as malware! Uninstall Shockwave, then reinstall it without the Norton malware.Report back how it goes. Quote Link to comment Share on other sites More sharing options...
andsome Posted January 4, 2009 Report Share Posted January 4, 2009 Norton is an absolute pain in the rectum. I hope you succeed in your efforts to get rid of it. :D Quote Link to comment Share on other sites More sharing options...
Amara Posted January 5, 2009 Author Report Share Posted January 5, 2009 So I uninstalled Norton Security Scan and then uninstalled and re-installed Shockwave and that seems to have fixed the problem. The only thing I noticed now is that when I restarted my computer after installing Shockwave my computer told me it couldn;t find Adobe Shockwave player in a certain location, but I'm not too worried about that; I think the new installation just placed it in a different location. Thanks for the suggestion and its so simple too I should of thought of it!! Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 6, 2009 Report Share Posted January 6, 2009 The latest version of Shockwave is 11.0.3.470, and it installs at C:\WINDOWS\system32\Adobe\Shockwave 11If you continue to get that message at Windows startup, please let us know. Someone will help you to get rid of it. Quote Link to comment Share on other sites More sharing options...
