Annihilator Posted January 18, 2009 Report Share Posted January 18, 2009 So I just bought a new laptop, wasn't paying attention to the fact that it's 64 bit, just liked that it was only a little more expensive for almost twice the goods. Now I can't install an important program.I know most programs work in x64 pretty easily now, but this program (called Hondata sManager) has a very small user base, and I'm having problems finding out how to make it work. It's the program I need to tune the ECU on my car, so it's pretty important to me. Any help would be GREATLY appreciated. - Steven Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 18, 2009 Report Share Posted January 18, 2009 Welcome to the Windows Forum.You write that you "can't install the program"; what happens - do you get an error message? Also, who wrote that program - do they give support for their users? Quote Link to comment Share on other sites More sharing options...
Annihilator Posted January 18, 2009 Author Report Share Posted January 18, 2009 Sorry for not adding that info.Error message comes up after installation into the "Program files (x86)" folder and I try to open the program. The message reads:"Unable to execute file: C:\Program Files (x86)\SManager\SManager.exe CreateProcess failed; code 5. Access is denied."The program comes from a website... www.hondata.com ...It's a tuning device for my car.Thanks - Steven Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 18, 2009 Report Share Posted January 18, 2009 I just checked their website http://www.hondata.com/, and they seem to have a tech support and forum (on the left-hand panel). I would first start there trying to get support.I don't have a 64-bit system, so I can't really help you. But maybe other forum members have 64-bit experience - i.e. how to run in 32-bit compatibility mode...? Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted January 18, 2009 Report Share Posted January 18, 2009 Maybe you just need to download the right install.exe for your 64bit machine if they have one available, or is the software you tried to install out-of-date. I don't see if it'd matter, but try with a newer version too if they have one available again. Quote Link to comment Share on other sites More sharing options...
stvh1 Posted February 11, 2009 Report Share Posted February 11, 2009 I have no trouble with my 64 bit.It is very fast ! One thing though, I would never get a laptop. All that computer cramed into a little laptop. That is trouble waiting to happen. Quote Link to comment Share on other sites More sharing options...
Katy Posted March 9, 2009 Report Share Posted March 9, 2009 Just checked the software on their site and it's running on both x32 and x64 systems. Make sure you are running the app under an Adminstrator account (XP), or in elevated mode (Vista). This software tries to access external hardware and you might run into trouble if don't have enough rights, hence the "Access denied" error. Quote Link to comment Share on other sites More sharing options...
