Wylbur Posted February 9, 2009 Report Share Posted February 9, 2009 Hi all;I need drivers for an old Albatron KX-600 Pro with Windows XP.I've purchased a license for Driver Detective, and used it on that system.My video performance actually got worse after downloading and installingthe driver listed with Driver Detective.What follows are the specs for my system. If anyone wants to know anythingmore, then please let me know.Any suggestions would be greatly appreciated.THANKS!!!-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Computer: Operating System Microsoft Windows XP Professional OS Service Pack Service Pack 3 DirectX 4.09.00.0904 (DirectX 9.0c) Motherboard: CPU Type AMD Athlon XP, 1833 MHz (11 x 167) 2500+ Motherboard Name Albatron KX600 Pro (5 PCI, 1 AGP, 3 DDR DIMM, Audio, LAN) Motherboard Chipset VIA VT8377 Apollo KT600 System Memory 512 MB (PC2700 DDR SDRAM) BIOS Type Award (09/17/03) Communication Port Communications Port (COM1) Communication Port Communications Port (COM2) Communication Port ECP Printer Port (LPT1) Display: Video Adapter RADEON 7000 / RADEON VE Family (Microsoft Corporation) (64 MB) Video Adapter RADEON 7000 / RADEON VE Family (Microsoft Corporation) (64 MB) 3D Accelerator ATI RV100 DDR Multimedia: Audio Adapter VIA AC'97 Enhanced Audio Controller Storage: IDE Controller VIA Bus Master IDE Controller - 0571 Floppy Drive Floppy disk drive Disk Drive Disk drive (74 GB, IDE) Optical Drive CD-ROM Drive SMART Hard Disks Status OK Partitions: C: (NTFS) 22105 MB (6339 MB free) D: (NTFS) 2008 MB (1995 MB free) E: (FAT32) 203 MB (203 MB free) F: (NTFS) 8008 MB (2792 MB free) I: (NTFS) 8008 MB (7966 MB free) J: (NTFS) 8008 MB (7558 MB free) K: (NTFS) 13648 MB (13549 MB free) Total Size 60.5 GB (39.5 GB free) Input: Keyboard Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse PS/2 Compatible Mouse Network: Network Adapter 3Com 3C910 Integrated Fast Ethernet Controller (3CSOHO100B-TX Compatible) Network Adapter VIA Rhine III Fast Ethernet Adapter (10.1.4.40) Peripherals: Printer Auto Fryer on OFFICE Printer Auto Prep on OFFICE Printer Microsoft XPS Document Writer USB1 Controller VIA VT83C572 PCI-USB Controller USB1 Controller VIA VT83C572 PCI-USB Controller USB1 Controller VIA VT83C572 PCI-USB Controller USB2 Controller VIA USB 2.0 Enhanced Host Controller--------[ DMI ]--------------------------------------------------------------------------------------------------------- [ BIOS ] BIOS Properties: Vendor Phoenix Technologies, LTD Version 6.00 PG Release Date 09/17/2003 Size 256 KB Boot Devices Floppy Disk, Hard Disk, CD-ROM, ATAPI ZIP, LS-120 Capabilities Flash BIOS, Shadow BIOS, Selectable Boot, EDD Supported Standards DMI, APM, ACPI, ESCD, PnP Expansion Capabilities ISA, PCI, AGP, USB [ System ] System Properties: Manufacturer VIA Technologies, Inc. Product KT600 Wake-Up Type Power Switch [ Motherboard ] Motherboard Properties: Product KT600 [ Chassis ] Chassis Properties: Chassis Type Desktop Case [ Memory Controller ] Memory Controller Properties: Error Detection Method None Error Correction None Supported Memory Interleave 4-Way Current Memory Interleave 4-Way Supported Memory Speeds 70ns, 60ns Supported Memory Types SPM, EDO Supported Memory Voltages 5V Maximum Memory Module Size 1024 MB Memory Slots 3 [ Processors / AMD Athlon XP ] Processor Properties: Manufacturer AMD Version AMD Athlon XP External Clock 167 MHz Maximum Clock 3000 MHz Current Clock 1837 MHz Type Central Processor Voltage 1.6 V Status Enabled Upgrade ZIF Socket Designation Socket A [ Caches / Internal Cache ] Cache Properties: Type Internal Status Enabled Operational Mode Write-Back Maximum Size 128 KB Installed Size 128 KB Supported SRAM Type Synchronous Current SRAM Type Synchronous Socket Designation Internal Cache [ Caches / External Cache ] Cache Properties: Type External Status Enabled Operational Mode Write-Back Maximum Size 512 KB Installed Size 512 KB Supported SRAM Type Synchronous Current SRAM Type Synchronous Socket Designation External Cache [ Memory Modules / A0 ] Memory Module Properties: Socket Designation A0 Speed 60 ns Installed Size Not Installed Enabled Size Not Installed [ Memory Modules / A1 ] Memory Module Properties: Socket Designation A1 Speed 60 ns Installed Size Not Installed Enabled Size Not Installed [ Memory Modules / A2 ] Memory Module Properties: Socket Designation A2 Type SDRAM Speed 60 ns Installed Size 512 MB Enabled Size 512 MB [ Memory Devices / A0 ] Memory Device Properties: Form Factor DIMM Device Locator A0 Bank Locator Bank0/1 Manufacturer None Serial Number None Asset Tag None Part Number None [ Memory Devices / A1 ] Memory Device Properties: Form Factor DIMM Device Locator A1 Bank Locator Bank2/3 Manufacturer None Serial Number None Asset Tag None Part Number None [ Memory Devices / A2 ] Memory Device Properties: Form Factor DIMM Size 512 MB Device Locator A2 Bank Locator Bank4/5 Manufacturer None Serial Number None Asset Tag None Part Number None [ System Slots / PCI0 ] System Slot Properties: Slot Designation PCI0 Type PCI Usage Empty Data Bus Width 32-bit Length Long [ System Slots / PCI1 ] System Slot Properties: Slot Designation PCI1 Type PCI Usage Empty Data Bus Width 32-bit Length Long [ System Slots / PCI2 ] System Slot Properties: Slot Designation PCI2 Type PCI Usage Empty Data Bus Width 32-bit Length Long [ System Slots / PCI3 ] System Slot Properties: Slot Designation PCI3 Type PCI Usage Empty Data Bus Width 32-bit Length Long [ System Slots / PCI4 ] System Slot Properties: Slot Designation PCI4 Type PCI Usage Empty Data Bus Width 32-bit Length Long [ System Slots / PCI5 ] System Slot Properties: Slot Designation PCI5 Type PCI Usage In Use Data Bus Width 32-bit Length Long [ System Slots / AGP ] System Slot Properties: Slot Designation AGP Type AGP Usage Empty Data Bus Width 32-bit Length Long [ Port Connectors / PRIMARY IDE ] Port Connector Properties: Internal Reference Designator PRIMARY IDE Internal Connector Type On-Board IDE External Connector Type None [ Port Connectors / SECONDARY IDE ] Port Connector Properties: Internal Reference Designator SECONDARY IDE Internal Connector Type On-Board IDE External Connector Type None [ Port Connectors / FDD ] Port Connector Properties: Port Type 8251 FIFO Compatible Internal Reference Designator FDD Internal Connector Type On-Board Floppy External Connector Type None [ Port Connectors / COM1 ] Port Connector Properties: Port Type Serial Port 16450 Compatible Internal Reference Designator COM1 Internal Connector Type 9 Pin Dual Inline (pin 10 cut) External Connector Type DB-9 pin male [ Port Connectors / COM2 ] Port Connector Properties: Port Type Serial Port 16450 Compatible Internal Reference Designator COM2 Internal Connector Type 9 Pin Dual Inline (pin 10 cut) External Connector Type DB-9 pin male [ Port Connectors / LPT1 ] Port Connector Properties: Port Type Parallel Port ECP/EPP Internal Reference Designator LPT1 Internal Connector Type DB-25 pin female External Connector Type DB-25 pin female [ Port Connectors / Keyboard ] Port Connector Properties: Port Type Keyboard Port Internal Reference Designator Keyboard Internal Connector Type PS/2 External Connector Type PS/2 [ Port Connectors / PS/2 Mouse ] Port Connector Properties: Port Type Mouse Port Internal Reference Designator PS/2 Mouse Internal Connector Type PS/2 External Connector Type PS/2 [ Port Connectors / USB0 ] Port Connector Properties: Port Type USB Internal Connector Type None External Reference Designator USB0 [ Port Connectors / AUDIO ] Port Connector Properties: Port Type Audio Port Internal Connector Type None External Reference Designator AUDIO External Connector Type None--------[ Overclock ]--------------------------------------------------------------------------------------------------- CPU Properties: CPU Type AMD Athlon XP 2500+ CPU Alias Barton CPU Stepping A2 CPUID CPU Name AMD Athlon XP 2500+ CPUID Revision 000006A0h CPU Speed: CPU Clock 1833.76 MHz CPU Multiplier 11.0x CPU FSB 166.71 MHz Memory Bus 166.71 MHz CPU Cache: L1 Code Cache 64 KB L1 Data Cache 64 KB L2 Cache 512 KB (On-Die, Full-Speed) Motherboard Properties: Motherboard ID 09/17/2003-KT600-6A6LYBKFC-00 Motherboard Name Albatron KX600 Pro (5 PCI, 1 AGP, 3 DDR DIMM, Audio, LAN) Chipset Properties: Motherboard Chipset VIA VT8377 Apollo KT600 Memory Timings 2.5-3-3-7 (CL-RCD-RP-RAS) Command Rate (CR) 2T SPD Memory Modules: DIMM3: Corsair CMX512-2700C2 512 MB PC2700 DDR SDRAM (2.5-3-3-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz) BIOS Properties: System BIOS Date 09/17/03 Video BIOS Date 03/06/12 Award BIOS Type Phoenix-Award BIOS v6.00PG Award BIOS Message R1.06 DMI BIOS Version 6.00 PG Graphics Processor Properties: Video Adapter PowerColor Radeon VE GPU Code Name RV100 (AGP 4x 1002 / 5159, Rev 00) GPU Clock 148 MHz (original: 150 MHz) Memory Clock 148 MHz (original: 150 MHz)--------[ CPU ]--------------------------------------------------------------------------------------------------------- CPU Properties: CPU Type AMD Athlon XP, 1833 MHz (11 x 167) 2500+ CPU Alias Barton CPU Stepping A2 Instruction Set x86, MMX, 3DNow!, SSE L1 Code Cache 64 KB L1 Data Cache 64 KB L2 Cache 512 KB (On-Die, Full-Speed) CPU Physical Info: Package Type 453 Pin PGA Package Size 4.95 cm x 4.95 cm Transistors 54.3 million Process Technology 6Mi, 0.13 um, CMOS, Cu Die Size 101 mm2 Core Voltage 1.65 V I/O Voltage 1.6 V Typical Power 53.7 - 60.4 W (depending on clock speed) Maximum Power 68.3 - 76.8 W (depending on clock speed) CPU Manufacturer: Company Name Advanced Micro Devices, Inc. Product Information http://www.amd.com/us-en/Processors/Produc...,30_118,00.html CPU Utilization: CPU #1 0 %--------[ CPUID ]------------------------------------------------------------------------------------------------------- CPUID Properties: CPUID Manufacturer AuthenticAMD CPUID CPU Name AMD Athlon XP 2500+ CPUID Revision 000006A0h Extended CPUID Revision 000007A0h Platform ID CBh (Socket A) IA CPU Serial Number Unknown HTT / CMP Units 0 / 0 Instruction Set: 64-bit x86 Extension (AMD64, EM64T) Not Supported Alternate Instruction Set Not Supported AMD 3DNow! Supported AMD 3DNow! Professional Supported AMD Enhanced 3DNow! Supported AMD Extended MMX Supported Cyrix Extended MMX Not Supported IA-64 Not Supported IA MMX Supported IA SSE Supported IA SSE 2 Not Supported IA SSE 3 Not Supported CLFLUSH Instruction Not Supported CMPXCHG8B Instruction Supported CMPXCHG16B Instruction Not Supported Conditional Move Instruction Supported MONITOR / MWAIT Instruction Not Supported RDTSCP Instruction Not Supported SYSCALL / SYSRET Instruction Supported SYSENTER / SYSEXIT Instruction Supported VIA FEMMS Instruction Not Supported Security Features: Advanced Cryptography Engine (ACE) Not Supported Data Execution Prevention (DEP, NX, EDB) Not Supported Hardware Random Number Generator (RNG) Not Supported Montgomery Multiplier & Hash Engine Not Supported Processor Serial Number (PSN) Not Supported Power Management Features: Automatic Clock Control Not Supported Enhanced Halt State (C1E) Not Supported Enhanced SpeedStep Technology (EIST, ESS) Not Supported Frequency ID Control Not Supported LongRun Not Supported LongRun Table Interface Not Supported PowerSaver 1.0 Not Supported PowerSaver 2.0 Not Supported PowerSaver 3.0 Not Supported Processor Duty Cycle Control Not Supported Software Thermal Control Not Supported Temperature Sensing Diode Supported Thermal Monitor 1 Not Supported Thermal Monitor 2 Not Supported Thermal Monitoring Not Supported Thermal Trip Not Supported Voltage ID Control Not Supported CPUID Features: 36-bit Page Size Extension Supported Address Region Registers (ARR) Not Supported CPL Qualified Debug Store Not Supported Debug Trace Store Not Supported Debugging Extension Supported Fast Save & Restore Supported Hyper-Threading Technology (HTT) Not Supported L1 Context ID Not Supported Local APIC On Chip Supported Machine Check Architecture (MCA) Supported Machine Check Exception (MCE) Supported Memory Configuration Registers (MCR) Not Supported Memory Type Range Registers (MTRR) Supported Model Specific Registers (MSR) Supported Page Attribute Table (PAT) Supported Page Global Extension Supported Page Size Extension (PSE) Supported Pending Break Event Not Supported Physical Address Extension (PAE) Supported Secure Virtual Machine Extensions (Pacifica) Not Supported Self-Snoop Not Supported Time Stamp Counter (TSC) Supported Virtual Machine Extensions (Vanderpool) Not Supported Virtual Mode Extension Supported CPUID Registers (CPU #1): CPUID 00000000 00000001-68747541-444D4163-69746E65 CPUID 00000001 000006A0-00000000-00000000-0383FBFF CPUID 80000000 80000008-68747541-444D4163-69746E65 CPUID 80000001 000007A0-00000000-00000000-C1C3FBFF CPUID 80000002 20444D41-6C687441-74286E6F-5820296D CPUID 80000003 35322050-002B3030-00000000-00000000 CPUID 80000004 00000000-00000000-00000000-00000000 CPUID 80000005 0408FF08-FF20FF10-40020140-40020140 CPUID 80000006 00000000-41004100-02008140-00000000 CPUID 80000007 00000000-00000000-00000000-00000001 CPUID 80000008 00002022-00000000-00000000-00000000 MSR Registers: MSR C0010015 0000-0000-0001-1008--------[ Motherboard ]------------------------------------------------------------------------------------------------- Motherboard Properties: Motherboard ID 09/17/2003-KT600-6A6LYBKFC-00 Motherboard Name Albatron KX600 Pro Front Side Bus Properties: Bus Type DEC Alpha EV6 Bus Width 64-bit Real Clock 167 MHz (DDR) Effective Clock 333 MHz Bandwidth 2666 MB/s Memory Bus Properties: Bus Type DDR SDRAM Bus Width 64-bit Real Clock 167 MHz (DDR) Effective Clock 333 MHz Bandwidth 2666 MB/s Chipset Bus Properties: Bus Type VIA V-Link Bus Width 8-bit Real Clock 67 MHz (ODR) Effective Clock 533 MHz Bandwidth 533 MB/s Motherboard Physical Info: CPU Sockets/Slots 1 Socket 462 Expansion Slots 5 PCI, 1 AGP RAM Slots 3 DDR DIMM Integrated Devices Audio, LAN Form Factor ATX Motherboard Size 200 mm x 300 mm Motherboard Chipset KT600 Motherboard Manufacturer: Company Name Albatron Technology Co., Ltd. Product Information http://www.albatron.com.tw/english/it/mb/pro_list.asp BIOS Download http://www.albatron.com.tw/english/service/bios.asp--------[ Memory ]------------------------------------------------------------------------------------------------------ Physical Memory: Total 511 MB Used 321 MB Free 190 MB Utilization 63 % Swap Space: Total 2280 MB Used 532 MB Free 1747 MB Utilization 23 % Virtual Memory: Total 2791 MB Used 853 MB Free 1937 MB Utilization 31 % Physical Address Extension (PAE): Supported by Operating System Yes Supported by CPU Yes Active No--------[ SPD ]--------------------------------------------------------------------------------------------------------- [ DIMM3: Corsair CMX512-2700C2 ] Memory Module Properties: Module Name Corsair CMX512-2700C2 Serial Number None Module Size 512 MB (2 ranks, 4 banks) Module Type Unbuffered Memory Type DDR SDRAM Memory Speed PC2700 (166 MHz) Module Width 64 bit Module Voltage SSTL 2.5 Error Detection Method None Refresh Rate Reduced (7.8 us), Self-Refresh Memory Timings: @ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS) @ 133 MHz 2.0-3-3-6 (CL-RCD-RP-RAS) Memory Module Features: Early RAS# Precharge Not Supported Auto-Precharge Not Supported Precharge All Not Supported Write1/Read Burst Not Supported Buffered Address/Control Inputs Not Supported Registered Address/Control Inputs Not Supported On-Card PLL (Clock) Not Supported Buffered DQMB Inputs Not Supported Registered DQMB Inputs Not Supported Differential Clock Input Supported Redundant Row Address Not Supported Memory Module Manufacturer: Company Name Corsair Memory, Inc. Product Information http://www.corsairmemory.com/corsair/products.html--------[ Chipset ]----------------------------------------------------------------------------------------------------- [ North Bridge: VIA VT8377 Apollo KT600 ] North Bridge Properties: North Bridge VIA VT8377 Apollo KT600 Revision 80 Package Type 664 Pin HSBGA Package Size 3.5 cm x 3.5 cm Process Technology 0.22 um Core Voltage 2.5 V In-Order Queue Depth 4 Memory Controller: Bank Interleave 4-way Memory Timings: CAS Latency (CL) 2.5T RAS To CAS Delay (tRCD) 3T RAS Precharge (tRP) 3T RAS Active Time (tRAS) 7T Command Rate (CR) 2T Memory Slots: DRAM Slot #1 512 MB (PC2700 DDR SDRAM) AGP Controller: AGP Version 3.05 AGP Status Disabled AGP Device PowerColor Radeon VE AGP Aperture Size 128 MB Supported AGP Speeds 1x, 2x, 4x, 8x Fast-Write Not Supported Side Band Addressing Supported, Disabled Chipset Manufacturer: Company Name VIA Technologies, Inc. Product Information http://www.via.com.tw/en/products/chipsets Driver Download http://www.viaarena.com/?PageID=2 Problems & Suggestions: Problem AGP is disabled. This may cause performance penalty. [ South Bridge: VIA VT8235 ] South Bridge Properties: South Bridge VIA VT8235 Revision 00 Package Type 487 Pin BGA Package Size 2.7 cm x 2.7 cm Process Technology 0.22 um Core Voltage 2.5 V AC'97 Audio Controller: Audio Controller Type VIA 8233/8235/8237 Codec Name Avance Logic ALC650 Codec ID 414C4720h S/PDIF Output Supported Chipset Manufacturer: Company Name VIA Technologies, Inc. Product Information http://www.via.com.tw/en/products/chipsets Driver Download http://www.viaarena.com/?PageID=2--------[ BIOS ]-------------------------------------------------------------------------------------------------------- BIOS Properties: BIOS Type Award Award BIOS Type Phoenix-Award BIOS v6.00PG Award BIOS Message R1.06 System BIOS Date 09/17/03 Video BIOS Date 03/06/12 BIOS Manufacturer: Company Name Phoenix Technologies Ltd. Product Information http://www.phoenix.com/en/products/default.htm BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40 Problems & Suggestions: Suggestion Are you looking for a BIOS Upgrade? Contact eSupport Today! Suggestion System BIOS is more than 2 years old. Update it if necessary.--------[ Windows Video ]----------------------------------------------------------------------------------------------- [ RADEON 7000 / RADEON VE Family (Microsoft Corporation) ] Video Adapter Properties: Device Description RADEON 7000 / RADEON VE Family (Microsoft Corporation) Adapter String RADEON 7000 / RADEON VE Family (Microsoft Cor BIOS String BK-AMI VER008.004.008.000 Chip Type RADEON 7000 AGP (0x5159) DAC Type Internal DAC(350MHz) Installed Drivers ati2dvag (6.14.10.6462) Memory Size 64 MB Video Adapter Manufacturer: Company Name ATI Technologies Inc. Product Information http://www.ati.com/products/gamer.html Driver Download http://www.ati.com/support/driver.html [ RADEON 7000 / RADEON VE Family (Microsoft Corporation) ] Video Adapter Properties: Device Description RADEON 7000 / RADEON VE Family (Microsoft Corporation) Adapter String RADEON 7000 / RADEON VE Family (Microsoft Cor BIOS String BK-AMI VER008.004.008.000 Chip Type RADEON 7000 AGP (0x5159) DAC Type Internal DAC(350MHz) Installed Drivers ati2dvag (6.14.10.6462) Memory Size 64 MB Video Adapter Manufacturer: Company Name ATI Technologies Inc. Product Information http://www.ati.com/products/gamer.html Driver Download http://www.ati.com/support/driver.html--------[ PCI / AGP Video ]--------------------------------------------------------------------------------------------- ATI RV100 DDR Video Adapter ATI RV100 DDR 3D Accelerator--------[ GPU ]--------------------------------------------------------------------------------------------------------- [ AGP 4x: PowerColor Radeon VE ] Graphics Processor Properties: Video Adapter PowerColor Radeon VE GPU Code Name RV100 PCI Device 1002 / 5159 Process Technology 0.18u Bus Type AGP 4x Memory Size 64 MB GPU Clock 148 MHz (original: 150 MHz) RAMDAC Clock 300 MHz Pixel Pipelines 1 TMU Per Pipeline 3 Pixel Fillrate 148 MPixel/s Texel Fillrate 444 MTexel/s Memory Bus Properties: Bus Type DDR Bus Width 64-bit Real Clock 148 MHz (DDR) (original: 150 MHz) Effective Clock 296 MHz Bandwidth 2368 MB/s Graphics Processor Manufacturer: Company Name ATI Technologies Inc. Product Information http://www.ati.com/products/gamer.html Driver Download http://www.ati.com/support/driver.html ATI GPU Registers: ati-00F8 04000000 ati-0140 0000AD00 ati-0144 1605354E ati-0148 DBFFD800 ati-0154 77777777 ati-0158 50320032 ati-0178 FF1F7855 ati-01C0 04FF0000 ati-4018 04040400 ati-CLKIND-0A 0142420C ati-CLKIND-0B 78005200 ati-CLKIND-0C 0400BC30 ati-CLKIND-0D FFFFFFFF ati-CLKIND-0E 0400A430 ati-CLKIND-0F 00000038 ati-CLKIND-12 0A000012 ati-MCIND-6C 00000000--------[ Desktop ]----------------------------------------------------------------------------------------------------- Desktop Properties: Device Technology Raster Display Resolution 1280 x 768 Color Depth 32-bit Color Planes 1 Font Resolution 96 dpi Pixel Width / Height 36 / 36 Pixel Diagonal 51 Vertical Refresh Rate 60 Hz Desktop Effects: Combo-Box Animation Enabled Drop Shadow Effect Enabled Flat Menu Effect Enabled Font Smoothing Enabled Full Window Dragging Enabled Gradient Window Title Bars Enabled Hide Menu Access Keys Enabled Hot Tracking Effect Enabled Icon Title Wrapping Enabled List-Box Smooth Scrolling Enabled Menu Animation Enabled Menu Fade Effect Enabled Minimize/Restore Animation Enabled Mouse Cursor Shadow Enabled Selection Fade Effect Enabled ShowSounds Accessibility Feature Disabled ToolTip Animation Enabled ToolTip Fade Effect Enabled Windows Plus! Extension Disabled Problems & Suggestions: Problem At least 85 Hz vertical refresh rate is recommended for classic (CRT) displays.--------[ Multi-Monitor ]----------------------------------------------------------------------------------------------- \\.\DISPLAY1 Yes (0,0) (1280,768)-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Quote Link to comment Share on other sites More sharing options...
Boris Posted February 9, 2009 Report Share Posted February 9, 2009 Motherboard drivers - (Motherboard Chipset VIA VT8377 Apollo KT600)Hyperion Pro V 5.22A http://www.viaarena.com/default.aspx?PageI...&CatID=1070Video drivers(RADEON 7000 PowerColor Radeon VE)ATI Catalyst 6.11http://ati.amd.com/support/drivers/xp/radeon-prer300-xp.html Quote Link to comment Share on other sites More sharing options...
Wylbur Posted February 10, 2009 Author Report Share Posted February 10, 2009 Motherboard drivers - (Motherboard Chipset VIA VT8377 Apollo KT600)Hyperion Pro V 5.22A http://www.viaarena.com/default.aspx?PageI...&CatID=1070Video drivers(RADEON 7000 PowerColor Radeon VE)ATI Catalyst 6.11http://ati.amd.com/support/drivers/xp/radeon-prer300-xp.htmlTHAT is just what I needed.THANKS BORIS!!!YOU ARE AWESOME!!!! Quote Link to comment Share on other sites More sharing options...
Boris Posted February 10, 2009 Report Share Posted February 10, 2009 We try to please :) Quote Link to comment Share on other sites More sharing options...
