Blackbox Posted March 3, 2009 Report Share Posted March 3, 2009 I cannot uncheck the mute box. I just did a system recovery. Can anyone help? thanks Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted March 3, 2009 Report Share Posted March 3, 2009 Sound hardware plugged in properly? And are the drivers working properly?It might be stuck on because one of these aren't... Quote Link to comment Share on other sites More sharing options...
Blackbox Posted March 3, 2009 Author Report Share Posted March 3, 2009 Sound hardware plugged in properly? And are the drivers working properly?It might be stuck on because one of these aren't...I don't know if the drivers are working properly or if I need to install them....is there a site I can go to that will check for me? thanks Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted March 3, 2009 Report Share Posted March 3, 2009 Go to Start Menu > Run type in "devmgmt.msc" and press ENTER and this will open up Device Manager.Check your sound drivers here. When you double click a device after opening the menu with the little + to the left of the words it will bring up a window and somewhere in it should tell you if it's working properly or not. Quote Link to comment Share on other sites More sharing options...
Blackbox Posted March 3, 2009 Author Report Share Posted March 3, 2009 Go to Start Menu > Run type in "devmgmt.msc" and press ENTER and this will open up Device Manager.Check your sound drivers here. When you double click a device after opening the menu with the little + to the left of the words it will bring up a window and somewhere in it should tell you if it's working properly or not.It says the driver is working fine but I still cannot turn off my mute? This is weird. I appreciate the help though. Any other suggestions? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 3, 2009 Report Share Posted March 3, 2009 ...is there a site I can go to that will check for me?http://www.drivermax.com/But anyway, I think we need to start earlier. You wrote that you "just did a system recovery"; why did you do that, and how did you do it?How did you get into mute mode; did you do it yourself? How do you try to uncheck the mute checkbox, from the systray or from the Control Panel's 'Sounds' applet? From 'Sounds', did you also try 'Advanced'? Quote Link to comment Share on other sites More sharing options...
Blackbox Posted March 3, 2009 Author Report Share Posted March 3, 2009 ...is there a site I can go to that will check for me?http://www.drivermax.com/But anyway, I think we need to start earlier. You wrote that you "just did a system recovery"; why did you do that, and how did you do it?How did you get into mute mode; did you do it yourself? How do you try to uncheck the mute checkbox, from the systray or from the Control Panel's 'Sounds' applet? From 'Sounds', did you also try 'Advanced'?My computer would not start up properly so thats why I did the recovery. The mute was already on when I first logged on after the recovery. I tried turning off the mute by going through the "advance" tab. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 3, 2009 Report Share Posted March 3, 2009 So what happens when you try to uncheck the 'Mute' checkbox - it will just stay checked? Have you tried to uncheck it with the Space bar?It could be a registry entry that does not allow you to access it; I will check where the 'Mute' status is held. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 3, 2009 Report Share Posted March 3, 2009 No, I cannot find it in the registry. No other ideas for now... Quote Link to comment Share on other sites More sharing options...
Blackbox Posted March 4, 2009 Author Report Share Posted March 4, 2009 When I try to uncheck the box nothing happens...the check just stays. I might as well not be clicking it at all. Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted March 4, 2009 Report Share Posted March 4, 2009 As far as what Pat said about the registry, they're probably somewhere in...\CCS\DeviceClasses\<dev class>\ ... But this will be mostly in Binary data and I wouldn't mess around with it unless I actually knew what I was doing. :)It may not be in the registry anyway as the restore would have cleared the data. Troubleshoot it. To do this:Go to Control Panel - which should be in the Start Menu > find Sounds and Audio Devices > Hardware (tab at the top) > Find your speakers in the list > Click Troubleshoot.Another thing is to make sure your computer has been set to actually use the speakers for its sounds.Control Panel > Sounds and Audio Devices > Audio > Sound Playback > Highlight your speakers' manufacturer/device name > Test HardwareAlso on the window go to Volume > Advanced > Speakers > make sure they are set here too.And check the Speaker Settings bit too.If all this fails, in the Control Panel, installing your audio drivers may have made an option to change its settings. Mine is Realteck HD Sound Effect Manager (which is a bunch of crap) but there may be some settings similar for you to try.If all that fails, try re installing the drivers. If that too fails, I don't know. Quote Link to comment Share on other sites More sharing options...
Blackbox Posted March 4, 2009 Author Report Share Posted March 4, 2009 I downloaded Driver Detective and after the first scan underneath "Sound, Video, and game controllers" my "Creative SB Audigy" was out of date and so was my "Emuzed EvcapMaui Device" (plus "creative game port" which I'm going go out on the limb and say it has nothing to do with my sound) What do you recomend I should do? I don't want to register with Driver Detective because of the money and I am sure there are other ways around this that I can handle myself. thanks Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted March 4, 2009 Report Share Posted March 4, 2009 Yeah man, there are. :) Just need to know the name of your hardware or drivers.What's the manufacture and model name of your speakers, and/or your driver names and version numbers? I'll search through the websites for the right one if you want.Also, what operating system are you using, including either 32 or 64 bit? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 4, 2009 Report Share Posted March 4, 2009 I downloaded Driver Detective and after the first scan underneath "Sound, Video, and game controllers" my "Creative SB Audigy" was out of date and so was my "Emuzed EvcapMaui Device" (plus "creative game port" which I'm going go out on the limb and say it has nothing to do with my sound) What do you recomend I should do? I don't want to register with Driver Detective because of the money and I am sure there are other ways around this that I can handle myself. thanksI don't know why you want to use "Driver Detective"... Why not use the free Drivermax suggestion I gave in my earlier post...? Quote Link to comment Share on other sites More sharing options...
