shokan Posted March 20, 2009 Report Share Posted March 20, 2009 I just did a full install of XP Pro SP2 on a Dell laptop Inspiron 8000. I used a CD-ROM in a modular bay where the floppy used to be. The original CD-ROM is busted. I changed the order of BIOS checking to be CD first, which is how I did the install. I then changed the boot order to be Internal HDD as first in line. I rebooted and all I ever get is a black screen (after the Dell splash screen) with the message "Fixed optical drive not found". Just in case, I then changed all three boot devices to Internal HDD. Nope, same result. I know XP is on the HDD; it went through the whole install perfectly. But when it rebooted, without the Xp disk in, I got the sequence of Dell screen then Fixed optical not found. Any suggestions, besides getting a new CD-ROM tht fits the original slot?Thanks. Quote Link to comment Share on other sites More sharing options...
Boris Posted March 20, 2009 Report Share Posted March 20, 2009 For background - this is shokan's previous topic on this :-http://forums.windowsforum.org/index.php?s...c=39664&hl= Quote Link to comment Share on other sites More sharing options...
shokan Posted March 20, 2009 Author Report Share Posted March 20, 2009 For background - this is shokan's previous topic on this :-http://forums.windowsforum.org/index.php?s...c=39664&hl= I need to install the RAID drivers when it prompts me to do so (F6) from a floppy. But, the problem is, the new CD-ROM is in the floppy slot now (the only place it fits) and is how I am able to install XP as far as I've gotten. Can I swap the CD-ROM drive at this stage of setup with the floppy drive and install the RAID drivers then put the CD-ROM drive back in the floppy slot to resume the setup with the XP CD? Quote Link to comment Share on other sites More sharing options...
Boris Posted March 20, 2009 Report Share Posted March 20, 2009 You will probably find it much easier to do this ?Add RAID drivers and Service Pack 2 to your original Windows CD! Quote Link to comment Share on other sites More sharing options...
shokan Posted March 20, 2009 Author Report Share Posted March 20, 2009 You will probably find it much easier to do this ?Add RAID drivers and Service Pack 2 to your original Windows CD! Yep, this would do it. Thanks.It's pretty involved but the instructions are clear. Quote Link to comment Share on other sites More sharing options...
