Operating System not loading
hi, I have a dual boot HD (ubuntu and windows xp) so yesterday I decided to make an upgrade to my desktop, I changed mother board, ram and video card, when I turned on the pc everything start great but when the screen of windows xp loading is supposed to appear instead a blue screen is shown, it goes very quickly so I have no Idea what it says, and then the pc restart automatically.
I boot a live disc of ubuntu and it ran normally so I assume the new hardware is working fine.
If anyone have an idea of why this is happening please help me out.
and of course if you have any question just let me know
thankx.
I assume the second time XP boots normally. I think that what's happening is that for some reason, on the first boot XP is crashing almost immediately then re-starting correctly. To help find out what's causing the crash check in Event Viewer as soon as you computer has successfully booted. To find Event Viewer go to Control Panel > Performance & Maintenance > Administrative Tools > Event Viewer, then examine all 4 logs for records of the crash. Right click any that you find & see what you can find out.
I think you'll find this problem is caused by your hardware changes & XP is still configured for the old set-up. Sometimes XP can cope with such changes, sometime it can't. You might only be able to solve this by re-installing XP, so, if you haven't already done so, make back-ups of you important data to prepare for this.
