nickster Posted June 11, 2009 Report Share Posted June 11, 2009 I have an AVI that Windows Media Player processes, shows video fine, but won't play the audio track. File properties show, uder the audio section, the length and bitrate, but not the audio format. Is there a program that extracts the audio stream and can convert it to something the player recognizes. BTW, my DVD player shows the file on the disk menu, but when I select it through my DVD player, it tries, then skips to the next movie (more than 1 movie on this DVD) Quote Link to comment Share on other sites More sharing options...
Boris Posted June 11, 2009 Report Share Posted June 11, 2009 Sounds like you are missing a codec ?Try this :-http://majorgeeks.com/K-Lite_Codec_Pack_Full_d4844.html Quote Link to comment Share on other sites More sharing options...
nickster Posted June 11, 2009 Author Report Share Posted June 11, 2009 Sounds like you are missing a codec ?Try this :-http://majorgeeks.com/K-Lite_Codec_Pack_Full_d4844.html Thanks. I just downloaded it and will apply. Quote Link to comment Share on other sites More sharing options...
