kiddd_ Posted July 22, 2009 Report Share Posted July 22, 2009 Hello everybody.It is like this :I've got a HP pavilion Elite model : m9554es on which I've created two partitions and installed XP on the second one ( It has Vista Home Premium on the first partition).I went to the manufacturer website ( HP that is ) and found out that there there was only ONE driver available from this model for Windows Xp ( Lightscribe ) , and no Vista driver is compatible with XP.However , I've managed to find and install succesfully all drivers for XP but ONE. --> eHome Infrared Transceiver <-- . I cannot manage to solve this one out . Does anybody have any ideas/suggestions on where may I find this driver ? Thank you a million ! Quote Link to comment Share on other sites More sharing options...
Boris Posted July 22, 2009 Report Share Posted July 22, 2009 I've managed to find and install succesfully all drivers for XP but ONE. --> eHome Infrared Transceiver Is this the device you refer to ?http://www.microsoft.com/downloads/details...;displaylang=enThat appears to be an actual Microsoft Driver + is part of Windows XP Media Center Edition 2005 ?Do you actually have one of these "eHome Infrared Transceiver"s on your motherboard ?......... and do you actually use it ? - if you don't use it, don't bother and just disable the device in Device Manager. Quote Link to comment Share on other sites More sharing options...
kiddd_ Posted July 22, 2009 Author Report Share Posted July 22, 2009 I've managed to find and install succesfully all drivers for XP but ONE. --> eHome Infrared Transceiver <--Is this the device you refer to ?http://www.microsoft.com/downloads/details...;displaylang=enThat appears to be an actual Microsoft Driver + is part of Windows XP Media Center Edition 2005 ?Do you actually have one of these "eHome Infrared Transceiver"s on your motherboard ?......... and do you actually use it ? - if you don't use it, don't bother and just disable the device in Device Manager.First of all thank you for helping me out. The computer is not mine , as I work as a computer technician for the summer so it is for a costumer of our company; that is why I have to make it work. Either if he wants to use it or not. I downloaded the package you told me to but I get this error : this hotfix requires kb888795. I'll try to run this one first and then the one you gave me. Thank you. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted July 23, 2009 Report Share Posted July 23, 2009 In case of driver difficulties, missing, unknown or old drivers: http://www.drivermax.com/ Quote Link to comment Share on other sites More sharing options...
