cabreat Posted September 16, 2009 Report Share Posted September 16, 2009 Hello everyone. Got a very simple one for you, unless it's impossible. My keyboard has recently started acting up, and every time I press the left arrow key it also activates the sleep key (the one with the little crescent on it). Every time I press the Sleep key, the left arrow key is also activated. The problem is that every time I press left now, the "Turn off computer" dialog pops up. So I'd like to prevent the Sleep key from doing anything.I know about the registry hack (HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer, set NoClose to 1), which solves the problem, but it also disables the power button on my computer and, after a restart, even the "Turn off computer" button on the Start menu vanishes.So I'm looking for one of two solutions.(1) A way to disable the Sleep key without messing with the power button or Start menu, or:(2) A way to run a file automatically when Windows is shut down, like the Startup folder but for shutting down. (That way, I can set up .reg files that enable and disable NoClose upon, respectively, Startup and Shutdown, and since the Start menu is modified only after a restart, if I set NoClose back to 0 before that restart, Windows will start up every time with the "Turn off computer" button enabled. Although the power button still won't work. And I suppose I'd have to press Enter to the dialog that pops up making sure I want to add the reg info, although there's probably a way to disable that too.)Obviously (1) would be simpler, but (2) is an option, though one I can't find a way to do. Any help would be appreciated! Quote Link to comment Share on other sites More sharing options...
cabreat Posted September 16, 2009 Author Report Share Posted September 16, 2009 Er... nevermind. As I suspected, the option is quite easy to get to. Just much easier than I remembered. Control Panel->Power Options->Advanced. Thanks anyway! Mods, delete this topic if possible, it's no longer relevant. Quote Link to comment Share on other sites More sharing options...
andsome Posted September 17, 2009 Report Share Posted September 17, 2009 If the problem has not in fact been solved, try uninstalling the software, cleaning up with C Cleaner, and reinstalling. :D Quote Link to comment Share on other sites More sharing options...
