Applications hang & System freezes
I have an unstable XP -SP2 installation that has evolved into the current state over the last few weeks. The terminating event is a crash preceded frequently by a " The task Master has encountered a problem and ... " statement. Similar statements have been "Google Taskbar Installer haes encountere a problem and needs to close" and "MSN Processor" same explanation
I have ran exhaustive virus and malware scans with Kaspersky and Malwarebytes.
System Overview:
Computer Type: Advanced Micro Devices 2833 MHz.
BIOS: AT/AT COMPATIBLE Date: 12/05/06
Memory: Total physical: 3326 MB. Used: 18%
Drives: 529 GB total free 1025 GB total size in 3 drives
Windows name and version: Multiprocessor Free (5.1.2600)
IE version: 6.0.2900.2180
DirectX Version: Unknow or Newer then DirectX 9.0c (4.09.00.0904)
BIOS Manufactured: Phoenix Technologies, LTD
BIOS Date: 12/05/2006
BIOS Version: ASUS M2N-E SLI ACPI BIOS Revision 0506
BIOS Size: 512 KB
Hard Drives
Drive: C
Total space: 279 GB (100%)
Free space: 41 GB (14%)
Used space: 239 GB (85%)
Drive: D
Free space: 279 GB (99%)
Used space: 0 GB (0%)
Drive: E
Total space: 466 GB (100%)
Free space: 209 GB (44%)
Used space: 256 GB (55%)
Memory Information
Total Physical Memory: 3326 MB
Total Windows Memory: 8532 MB
Free Memory: 7481 MB
Used Memory: 1051 MB
Page Size: 4096 bytes
Total threads: 590
Total processes: 45
PageFile Total Size: 5330172 KB (100%)
PageFile Used: 439992 KB (8%)
PageFile Free: 4890180 KB (92%)
The Event log records show some Information and Error Events:
Typical Information [with "service stopped"] >>
The description for Event ID ( 0 ) in Source ( gusvc ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: Service stopped
________________________
Error>>
Date : 9/20/2009 Source : Application Error
Time: 11:33:25 Category : None
Type : Error Event: 1000
Description:
Faulting application msntask.exe, version 3.0.1125.0, faulting module mscoree.dll, version 2.0.50727.3053, fault address 0x00005810.
______________
[ii]
Date : 9/20/2009 Source : Application Hang
Time: 11:29:13 Category : None
Type : Error Event: 1001
Description:
Fault bucket 126637809.
______________
[iii]
Time: 11:29:06 Category : (101)
Type : Error Event: 1002
Description:
Hanging application iexplore.exe, version 6.0.2900.2180, hang module hungapp, version 0.0.0.0, hang address 0x00000000
______________
You could make a start by updating to SP3.
As with this MSNTASK.exe, using the MSN Toolbar with IE 6 just slows it all down - I've read many support pages mentioning this issue in the past. Updating IE will help with that.
The Google Taskbar error could lead to being a non-existant problem which is just used by malware. If so, Trend Micro will find it and sort it out for you - HouseCall - Trend Micro is an online virus scanner. Completely safe and recommended by many of the users on this forum.
Here are some Microsoft support pages describing the errors.
Error Event: 1000 :
http://support.microsoft.com/kb/185198
Error Event: 1001 :
http://support.microsoft.com/kb/271213
Error Event: 1002 :
http://support.microsoft.com/kb/891608
So really, the majority of it is down to updates containing files that replace some of the DLL's that are currently in your XP SP2 version - some of which will remove the errors.
Had installed SP3 but had to do a rollback - heaps of problems. Will look into your suggestions - THANKS!
Error Event: 1000 :
Error Event: 1001 :
Error Event: 1002 :
Problems with SP3? But SP3 is much more reliable than SP2 and the speed is noticeably different. :)
If you're having problems, make sure you are able to update every device driver that can be installed on SP3 and your system is clean from virus infections, malware, all that stuff.
