Hb_Kai Posted September 22, 2009 Report Share Posted September 22, 2009 I was wondering... is there a way to connect a PS2 to two TV's at one time to play 2-player games so that the 2-player functionality won't split the screen in half for each person?All a PS2 really has is one port for a single Audio/Video AV Cable and another port for an AC Power Cable.It has one USB socket though if that helps?But then there's the other problem which is, if this was done by using two AV cables both plugged into an adapter, would it still split the screen or produce two split-screens on the TV's?The split screen thing is incredibly annoying when trying to play a game with someone else - they can always see what you're about to do and it makes it harder to win and also, makes it harder to see. Link to comment Share on other sites More sharing options...
mark123 Posted November 19, 2009 Report Share Posted November 19, 2009 Your post it very interesting dear.It is a good idea,But i don't think so that it is going to be possible.If i m wrong than do tell me. Link to comment Share on other sites More sharing options...
bolton154 Posted September 22, 2012 Report Share Posted September 22, 2012 its really great idea and also interesting idea, but in my opinion its not possible for you. if you can do it then you will definitely tell us. Link to comment Share on other sites More sharing options...
