Vladislak Posted September 28, 2009 Report Share Posted September 28, 2009 Okay, so I'm trying to run a program with the compatibility set to Windows XP (Service pack 2), it's not going so well.I was told that it may work if I run the program as an administrator by right-clicking on the application, going to properties, then into the compatibility tab. Then I should see a checkbox for running the program as an administrator.All of this worked perfectly, except I can't check off the box that let's you run it as an administrator, it's grayed out and not available.I don't see why I wouldn't have permission to check it off, I'm the only user of the comp and I should have full privileges...Any help would be greatly appreciated, thanks in advance. Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 28, 2009 Report Share Posted September 28, 2009 What operating system? You state "compatibility set to Windows XP (Service pack 2)" suggesting the main O/S is something different. Even so, why aren't you up to date with service pack 3? It may not cure your problem but it can't do any harm. Quote Link to comment Share on other sites More sharing options...
Vladislak Posted September 28, 2009 Author Report Share Posted September 28, 2009 Oh, sorry. I should have mentioned that earlier. I'm using Vista. >_>The reason I'm running the program with service pack 2 is because it won't run by default and service pack 2 was recommended to fix the problem.I didn't realize there was a service pack 3 though. Quote Link to comment Share on other sites More sharing options...
