Muzzammil Hussain Posted November 15, 2009 Report Share Posted November 15, 2009 I have windows xp professional service pack 2 and have 20 computers in my home network only one has dvd rom i want to install windows on all other 19 computers through a network how i can do this? Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted November 15, 2009 Report Share Posted November 15, 2009 Is that possible? Quote Link to comment Share on other sites More sharing options...
dbruce Posted November 15, 2009 Report Share Posted November 15, 2009 Is that possible? Best bet would be to download a USB image for creating a bootable USB. Some images have network connectivity installed. If the machine is newer, many have bootable network cards that will pull an OS off the network, though I have not done this myself. Takes time to figure this one out, so if you are in a hurry, probably not the best option. Here is how to do it in Ubuntu.....I am sure a Windows method is available:https://help.ubuntu.com/community/Installation/NetbootThe easiest option is to get the bootable USB with the install image on it and install from the USB. Only warning is to make sure you have Smartdrv or some other cache program loaded (in DOS) or the install will take hours. Quote Link to comment Share on other sites More sharing options...
dbruce Posted November 15, 2009 Report Share Posted November 15, 2009 http://www.computing.net/answers/windows-2...l-os/63491.htmlhttp://www.computing.net/answers/windows-x...pro/135778.html Quote Link to comment Share on other sites More sharing options...
Tod Cunningham Posted September 27, 2010 Report Share Posted September 27, 2010 Install those software in DVD drive system.Then use GHOST 11 software ,It is used to make Images of your Bootable drive,Then Make you PAN Drive As boobtable, Install this Images is all other Computers easily. GHOST 11 easily available on internet. Quote Link to comment Share on other sites More sharing options...
